Need help/advice sailing from NYC to Marthas Vineyard - Page 2 - SailNet Community
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you.
 2Likes
post #11 of 21 Old 08-31-2015
Tartan 27' owner
CalebD's Avatar
Re: Need help/advice sailing from NYC to Marthas Vineyard
We are all sounding like a bunch of safety weinies.
I say go for it.
Everybody has one:
CalebD is online now
post #12 of 21 Old 08-31-2015
CLucas's Avatar
Send a message via AIM to CLucas
I say go for it.
Well... keep in mind the original poster is new on this forum and is someone we know nothing about in terms of experience, etc. Nobody has said anything that isn't readily apparent on a chart. The OP asked for opinions presumably because they wanted them and weren't 100% confident about going outside.
I would never tell anyone to go for it without knowing for certain they were up to the task. What's the worst that could happen? There's plenty of sad stories to choose from. So yeah, I'm a safety weenie. Guilty as charged.
CalebD likes this.
s/v Grey Goose
1977 Pearson 30 #995
~~~~~~_/) ~~~~~~
CLucas is offline
post #13 of 21 Old 09-01-2015
fallard's Avatar
Since this is a new boat to the OP, it would not be a good idea to do a real shakedown on the outside, especially because the inlets to the east are notoriousy treacherous in adverse conditions.
Agree with others who have recommended the LIS route for all the reasons stated. I would also recommend staying inside Fishers Island Sound, minding all the rocks along that way until past Watch Hill Passage.
Minding the Eldridge Tide and Pilot book is an absolute necessity, primarily for timing passages, but also for safety in areas like the Race (south of New London).
Also, I would be surprised if the average speed for a Stonehorse 23 is as high as 4kts, especially there is a dinghy under tow, as the current will not always be fair and favorable winds synchronized with favorable currents is wishful thinking. This sounds like an endurance contest even if the weather is perfect. Making it to BI in 4-5 days would be an accomplishment IMHO.
fallard is online now
post #14 of 21 Old 09-01-2015
Bristol 45.5 - AiniA
I guess I am a safety weinie too - at least for myself. Obviously we have done some challenging passages, but have always weighed the odds. In this case, with a new to me boat I would take the inside passage. If things worked well I might choose the outside passage for the return trip.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #15 of 21 Old 09-01-2015
Over Hill Sailing Club
smurphny's Avatar
If you can get inside, maybe through Fire Island Inlet (follow a local commercial boat in) into Great South Bay, you can make it out to Gardiner's Bay/Block I. Sound through the Shinnecock Canal. This requires going through Moriches Bay which is notorious for its shoals. I have been through there a number of times with a 3' draft but it needs to be a sunny day with someone up on the bow to spot the sand bars. It's a scenic, interesting trip, going in and around Shelter Island and such but a lot of work. I'd opt for the East River and LI Sound.
smurphny is offline
post #16 of 21 Old 09-01-2015
That's an ambitious cruise in that timeframe. At 4kts, it must be at least 50 hrs of sailing, probably closer to 75, after tacking/gybing/headwinds/foul current, etc, is my guess. Even 1kt of foul current is going to seriously extend a trip on a 4kt boat. Are you sailing through the night or planning 12 to 15 hour days?
Add me to the chorus of taking the route through the Sound. You could certainly find bad weather and some rough seas over 5 days. You'll need to prepare for a bailout or to be held up. Comes with the territory.
Beautiful time of year for that trip. Crowds are down after Labor Day. Weather is usually warm during the day and cooler at night and the breeze is up. However, storms are storms and they are still around.
When are you going to return to NYC? Unfortunately, weather does start to go downhill fast in Sept.
Jeanneau 54DS
Minnewaska is offline
post #17 of 21 Old 09-01-2015
That is a nice route, though chances are it would be a motor job virtually the entire way...
Only problem is, the fixed bridge clearance of only about 21' over the Shinnecock Canal...
I agree with most others, sounds like LI Sound is the better way for these folks to go...
JonEisberg is offline
post #18 of 21 Old 09-01-2015
fallard's Avatar
There are 3 problems with the inside-the-barrier-island route. 1.) shallow water, particulary at the east end of Great South Bay and in Moriches Bay. 2.) there are several draw bridges to deal with and the reversing currents can be a challenge for a sailboat if not timed correctly (you will not be able to hold a fair current all the time). 3.) There is a 25' fixed bridge clearance in the Shinnecock canal, requiring you to remove your mast and restep it (assuming the gin poles are still there). Agree with smurphny's conclusion about the scenic part, though.
post #19 of 21 Old 09-01-2015
smurphny's Avatar
Oops. Have only gone that way in powerboats so didn't even think about the clearance.
smurphny is offline
post #20 of 21 Old 09-01-2015
You are getting good advice to go inside. You should consider at least Moriches and Shinnicock inlets as un-navigatable. Even after rounding Montauk Point, if you are looking for rest or shelter you have to sail to the harbor which is a couple of hours to the west. Then you'll lose another couple of hours going back East when you leave.
If you go inside to, say, Oyster Bay, then Mattituck or Essex Ct., and on the BI. Sail with the current as much as possible. That will be a memorable trip. The outside route will be an endurance ordeal.
shemandr is offline
Tags
marthas vineyard , nyc , sailing advice
Any Advice for sailing Kingston, NY to NYC?? Grampian1989 Seamanship & Navigation 12 10-02-2015 03:41 PM
Marthas Vineyard, Greenport, Block Island, Port Jeff, Matiuk, Stonington, New Lo chef2sail Long Island 94 09-04-2012 08:39 AM
Long Island Sound/ Cuttyhunk and Marthas Vineyard Trip chef2sail Chesapeake Bay 2 03-21-2012 09:25 AM
Newport ( formerly Marthas Vineyard ) 0r bust chef2sail Chesapeake Bay 20 08-16-2010 04:25 PM
Seeking advice for Martha's Vineyard Dylanmaven Cruising & Liveaboard Forum 2 08-09-2009 10:56 PM
HTML code is Off
