Hello! Anyone know this boat? - SailNet Community
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you.
 2Likes
  • 1 Post By Faster
  • 1 Post By replusted
post #1 of 9 Old 02-27-2016 Thread Starter
Hello!
I have recently purchased what was advertised as a 420. After briefly looking at it over, it was pretty obvious that this was not a 420. But, it was $100.00 with the trailer, so I picked it up. (I'm really becoming passionate about rehabbing these small sailboats!)
The only problem is that I can't find a hull identification number, anywhere, and the guy that I got it from doesn't know anything about sailing (the boat belonged to a friend that moved away, or something.)
If anyone can help me identify the boat, so that I can research what it should look like, how to rig it, sails to buy, etc. that would be great! I'll try to post some pics.
Thanks!
Dave
Dimensions:
LOA - roughly 15' 6 3/4"
Beam - 5'9"
Mast (2 part) 22' 1"
Boom - 9' 2 7/8"
davidikard is offline
post #2 of 9 Old 02-27-2016
Re: Hello! Anyone know this boat?
It's a distant shot, but maybe a Laser II? Any spinnaker gear?
davidikard likes this.
Faster is offline
The Following User Says Thank You to Faster For This Useful Post:
davidikard (02-27-2016)
post #3 of 9 Old 02-27-2016 Thread Starter
No, but I can't quite make sense of all of the rigging. (I'm new to sailing, even though this is my third dingy rehab, since October.) I'll try to upload some more pictures. I'm also making a picture album. I'll try to forward you the address.
Thanks!!!
post #4 of 9 Old 02-27-2016
replusted's Avatar
Did any sails come with the boat? Look at the main sail. It should have an insignia on it which will help us identify the boat. Post a picture of that. You should also check the starboard side of the transom for a hull identification number. Within that number it will identify the manufacturer.
replusted is offline
The Following User Says Thank You to replusted For This Useful Post:
post #5 of 9 Old 02-27-2016 Thread Starter
No sails. It's a bit of a quagmire....
Would any other pictures help?
Thanks!
post #6 of 9 Old 02-27-2016
I don't recognize it. I would suggest asking on Sailing Anarchy's Dinghy sub forum. Someone there may recognize it.
Greg
Stumble is offline
post #7 of 9 Old 02-27-2016
You might search sailboat.com by entering an appropriate range of boat lengths - say 15.5 to 15.7. You'll end up with a small pool (no pun intended) to search.
Hudsonian is offline
post #8 of 9 Old 02-28-2016
captflood's Avatar
GREETINGS EARTHLINGS Saw your pics try looking at a 505 I can not remember who made them they are fast and can be a bit wet when flying full sail . AS ALWAYS GO SAFE
captflood is offline
post #9 of 9 Old 02-28-2016
krisscross's Avatar
Since you have a mast and a boom, you can measure all the required dimensions (luff and foot) and get a used sail. Do not get a sail that is bigger. Modifying sails is absurdly expensive. A slightly smaller sail would be fine since you are learning to sail. Smaller sail is much easier to control. This dinghy most likely just has a main sail, no jib. It should not be hard to rig. Try to find an experienced dinghy sailor in your area to walk you through it.
Plato
krisscross is offline
'Boat Bandit' Arrested In String Of Boat Paraphernalia Thefts - CBS Local NewsReader News Feeds 0 03-07-2015 06:50 AM
Wooden boat has a write up on an electric boat repower sept/oct 2013 davidpm Gear & Maintenance 0 08-20-2013 09:48 PM
HTML code is Off
