Bought my 1st sailboat - Page 2 - SailNet Community
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you.
 5Likes
post #11 of 19 Old 05-31-2016 Thread Starter
nowiscertain's Avatar
Re: Bought my 1st sailboat
Originally Posted by nowiscertain View Post
Think I got the picture thing down. I've only these three at present. Boats in San Diego, I'm in L.A. but I'll have more after Sat. Good Lord willing, and all that. [emoji256]
Sent from my SM-T310 using Tapatalk
nowiscertain is offline
post #12 of 19 Old 05-31-2016 Thread Starter
Originally Posted by Lake Superior Sailor View Post
Well how kool is that! Great to see dreams achieved! We will want pictures!....Dale
Trying again
post #13 of 19 Old 06-01-2016
Lake Superior Sailor's Avatar
Nice Pictures, looking good!....Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #14 of 19 Old 06-08-2016 Thread Starter
The haul out, hull is fine, but meglected. Propneeds replacing, lots of metal showing on the keel, keel bolts are all rusted and the plates flaking. Nothing too bad, I'm told, but how would I know?
Brin - 1964 Center Belly Button
Catharsis - 1973 Coronado 35 Center Cockpit
California - Channel Islands National Park
Dream - Galapagos Islands
post #15 of 19 Old 06-08-2016 Thread Starter
Let me try that again...
post #16 of 19 Old 06-08-2016 Thread Starter
post #17 of 19 Old 06-18-2016 Thread Starter
Well, she didn't pass survey. Back to the grind as the search continues...siiiiiiiigggggghhhhh...
Brin - 1973 Coronado 35' Center Cockpit
For my living and cruising pleasure.
post #18 of 19 Old 06-18-2016
For our education can you tell us what the issue was with the keel on Catharsis? Were there signs of structural damage or instability that the surveyor found?
nowiscertain likes this.
Skyeterrier is offline
post #19 of 19 Old 06-18-2016 Thread Starter
I can only tell you that the surveyor thought that the plates needed replacing, lots of rust detrioration, and that there were some leaks. Also that the bolts might need replacing. He pointed out that one of the nuts was almost completely corroded in one area. Also, there was extensive demetaling on the outside of the keel, as well as of the prop. Whenthe yard got in there they felt that they would need to drop the jeel and filly replace the bolts in order to seal up the leaks. There was a good deal of water in the dry bilge about the keel plates.
So short answer, yes. There were structural problems related to corrosion. I'm not sure what is meant by "stability." If you're asking if the keel wobbled back and forth, the answer is no. If you're referring to holding point under sail, I did not investigate that issue.
The sad part is that I had formed a friendship with the owner, and here he is trying to foist this decrepid wreck on me. A tad hyperbolic, but the meaning is the same. He was all for saving me money by trying to convince me that a survey was unecessary. I go by an axom, however, when it comes to buying boats. One that has served me well. It goes a little something like this: "I'm more certain to get a survey on a boat than wear a condom when I'm f**king."
And I always suit up for that latter
Bought my 1st sailboat Towguy Introduce Yourself 14 05-27-2016 01:18 AM
Got my 1st sailboat today! serpa4 Gear & Maintenance 20 05-15-2016 10:52 AM
1st boat. Just bought a Tanzer 7.5 Guyfromthenorth Introduce Yourself 4 07-02-2015 05:08 PM
1st boat! I just bought a Catalina 22 Minnesail General Discussion (sailing related) 26 10-10-2013 09:38 AM
Hi from PA.- Bought my 1st boat!!- Cal21 sailpa65 Introduce Yourself 3 09-13-2010 10:15 PM
HTML code is Off
