Hello from New Jersey - SailNet Community
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you.
 2Likes
post #1 of 11 Old 10-08-2018 Thread Starter
Hello! I'm on the northern side of 40 and own a small business repairing leather, vinyl and fabric.
I just bought a new to me 1983 Starwind 19 from the son of the original owner who passed a year ago. I'm new to sailing, I've read a bunch of books, looked online at lots of websites and gone on some tourist help sail cruises. This means I'm basically clewless as far as sailing is concerned. I've owned a few power boats ranging from jet skis (sea knats), to outboard powered bow riders to pontoon boats to a tritoon including the most recently purchased new two years ago Harris tritoon which I keep on the water at a lake in New Jersey.
I'm excited to get into sailing with my 19 foot trailer sailer. I'm hoping to get her wet before this season is through in New Jersey / New York. I've been going over the boat and ordered new shrouds and a new forestay which should be arriving this week. I picked up a 6hp Yamaha outboard and I'm getting the trailer in shape to hit the road.
I'm looking forward to chatting and learning from the forum on this new adventure for me!
I have as ton of questions but may need to put them somewhere else.
I'm wondering how I set up the main sheet.
The boat has two tracks on each side of the companionway entrance with blocks. I'm thinking they are for the jib sheets. There are also swivel blocks with cam cleats just aft of the tracks.
The boat doesn't have any winches. I'm figuring my fiddler block attaches to the boom tang and the lower two blocks need to attach to a tang on the aft railing/pulpit. I have a bunch of pad eyes but they are on the outside edges of the boat. Some run under the windows and continue all the way to the stern. I don't have a traveler so I'm unsure how to run the mainsheet.
Any help would be greatly appreciated!
Thanks!!!
Mike
Mike
1983 Starwind 19
Planning on getting this boat wet before the season is past me ... and keeping the inside dry !!!
MikePNJ is offline
post #2 of 11 Old 10-08-2018
Captain Obvious
Sal Paradise's Avatar
Re: Hello from New Jersey
Welcome Mike
Is your mast up? You may need to do a dry run of your rigging set up. Does your boat look like this one?
Sal Paradise - Armchair Circumnavigator
Senior Researcher - Dunning Kruger
Sal Paradise is offline
post #3 of 11 Old 10-08-2018 Thread Starter
Yes it looks exactly like that. The back of the main sheet just attaches to the aft pulpit / railing? There are 2 tangs on that rail. I attached the backstay to one of them. No other cleats to run it though. I don't have any life-lines or stantions either. Same jack plate with block of wood on it. I can't see a back stay in the picture and barely can make out possibly the shrouds. It almost looks like a fake picture though, sails looked perfectly trimmed without any way to do it, and he's just working a tiller while his wife and child stare at something in the distance behind them.
Mike
1983 Starwind 19
MikePNJ is offline
post #4 of 11 Old 10-09-2018 Thread Starter
I don't have a boom vang set-up on my boom. I have 1 horn cleat and a block which I believe is for the outhaul.
From the picture I don't really see any lines to control the mainsheet or even the lines running back from the jib. I see the connection point but how do you pull the main sheet in or let it out from this set-up?
Thanks,
Mike
MikePNJ is offline
post #5 of 11 Old 10-09-2018
Captain Obvious
Thanks,
Mike
Thanks,
Mike
If you look at the attachment of the sheet in the pic you will see the main sheet attached to the traveler. That little rail is not really a rail, its to allow the angle of the main sheet to be adjusted. The main sheet block should attach to that little traveler with a shackle or a special bracket that has wheels to roll back and foorth on the " rail" .
I have a Cat 22 so for reference here is what I am thinking of.. your boat should be similar.
MikePNJ likes this.
The Following User Says Thank You to Sal Paradise For This Useful Post:
MikePNJ (10-09-2018)
post #6 of 11 Old 10-09-2018
PhilCarlson's Avatar
Dock
...I'm basically clewless...
I see what you did there! Nice!
Welcome aboard!
MikePNJ likes this.
PhilCarlson is online now
The Following User Says Thank You to PhilCarlson For This Useful Post:
post #7 of 11 Old 10-09-2018 Thread Starter
Thanks Sal. That makes more sense to me. Now to hunt down that traveler car. It helps me that it was used an a Cat 22. I just hope the rail diameter is the same. I found one on Catalina direct for $52.
Would I connect the fiddle block to the boom or the end closer to the rail? Or would I connect that shackle on the end of the double block to the rail without the traveler car? Here are more mainsheet pictures.
20181009_085920_1539092129477.jpg   20181009_090004_1539092163977.jpg   20181008_163818_1539092175236.jpg
Mike
1983 Starwind 19
MikePNJ is offline
post #8 of 11 Old 10-09-2018
Captain Obvious
Well I would think you would want to adjust the sheet from the back, as in a cat 22.
When I first got my boat, the block was attached to the traveler rail with a simple stainless steel shackle and it worked fine.
post #9 of 11 Old 10-09-2018 Thread Starter
That explains why the PO has two plumbing valves attached to that rail. Must be to stop the shackle from falling over the ends!
Mike
1983 Starwind 19
MikePNJ is offline
post #10 of 11 Old 10-10-2018
Captain Obvious
Not much time to get this baby into the water, Mike
Hello from New Jersey tangent Introduce Yourself 18 03-06-2014 04:48 PM
New Jersey Herald - 2 rescued when sailboat runs aground in south NJ - New Jersey Her NewsReader News Feeds 0 07-07-2013 01:00 PM
New Jersey Herald - Coast Guard aids woman hurt in sailboat accident - New Jersey Her NewsReader News Feeds 0 06-11-2013 10:40 PM
Jersey Journal Update (The Jersey Journal) NewsReader News Feeds 0 07-02-2006 12:15 PM
Jersey & France. Commodore’s Cup & Cook Salvers Jersey to St Malo races @ BYM Sailing News NewsReader News Feeds 0 04-21-2006 07:15 AM
HTML code is Off
