Allmand 31 keel cement? - SailNet Community
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you.
 2Likes
  • 1 Post By roverhi
  • 1 Post By Jeff_H
post #1 of 9 Old 05-06-2019 Thread Starter
Sherry Morphet's Avatar
Hello everyone. I joined this forum a couple of years ago, I have a 1982 C&C MKII which I’m currently selling because I’ve just bought a 1981 Allmand 31which needs a little bit of love. I am concerned about the keel. I have read they are iron, but a good chunk is missing and it definitely looks like cement? Also there is moisture dripping😳 I will enclose a pic. Thanks for your advice/thoughts.
Sherry Morphet is offline
post #2 of 9 Old 05-07-2019
roverhi's Avatar
Re: Allmand 31 keel cement?
If the ballast is internal it was not unknown to cover the ballast with cement and even mix steel punchings with concrete. Typically this was done on wooden boats but also on fiberglass especially amateur finished hulls. Not my idea of the best way to build a boat but works.
Sherry Morphet likes this.
roverhi is online now
post #3 of 9 Old 05-07-2019
Administrator
Jeff_H's Avatar
Like many of the internal ballasted boat builders of that era, Allmand used a mix of concrete and a ballast material for their keels. If your boat has the short rig, most likely the ballast is iron pigs and steel boiler punchings in concrete. Allmand offered a tall rig and if you selected the tall rig there was an optional lead keel that went along with it. My recollection is that the ballast in the lead keel version was lead shot mixed in polyester resin. If your keel appears to be cement, that probably means that it is the iron ballasted-short rig version of the boat.
Iron ballast in concrete is about the worst form of ballast that is out there. Ignoring that it is very low densiity, sooner or later water can get to the iron and start to rust it. Over time you end up with a bilge full of broken up concrete that has iron in it making it harder to remove.
Jeff_H is online now
post #4 of 9 Old 05-07-2019 Thread Starter
Thanks guys for your reply, that doesnt sound like it will be an easy job!
I drilled a small hole up into the keel, water is coming out of it, it is not rusty but whitish from the cement I gather. Lets see what happens. Watch this space or not! yikes!
post #5 of 9 Old 10-04-2019
Any progress with your keel? I have a Bombay Clipper 31, sort of a cousin to the Allmand 31, same designer Walter Scott. I too have/had water in my keel. I drilled some holes to let it drain. Now I am doing a long term refit. I have it on a trailer in my barn and am stripping the hull to do a complete blister repair, lots and lots of sanding!
sn001 is offline
post #6 of 9 Old 10-05-2019 Thread Starter
Hi, I had drilled a couple of holes to allow it to drain and dry out as much as I could before it was put into the water... we shall see how it is in a few weeks when it comes out. Yours sounds like a big job! I Aldo gad to replace the top rudder shelf, it was completely rotted out.
post #7 of 9 Old 10-08-2019
Dirt Free
boatpoker's Avatar
and Pacific Seacraft among others
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #8 of 9 Old 12 Minutes Ago Thread Starter
Allmand 31 bomar port lenses
I don’t know if it’s just me, and it probably is, but the interface of the Sailnet forum makes it difficult to post. So hopefully this post is in the correct spot!
I have a 31 Allmand 1981 and I’m looking for 6 smoke lenses for my port windows they are G512. I have contacted Pompanette, but they are super expensive for each. Any other suggestions ? Only the lenses are required. Thanks a lot!
post #9 of 9 Old 5 Minutes Ago
Acrylic and poly carb are easily sourced.
Jigsaw and some masking tape...be patient and exact..you are done cheaply
RegisteredUser is online now
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
RegisteredUser
ALLMAND 31 sclafever Boat Review and Purchase Forum 39 02-22-2016 04:13 PM
need Allmand 31 keel info alman Gear & Maintenance 6 09-14-2012 04:14 PM
Allmand 31 sclafever Boat Review and Purchase Forum 0 02-13-2001 02:08 PM
Allmand 31 sclafever General Discussion (sailing related) 0 02-13-2001 02:06 PM
Allmand 31 sclafever General Discussion (sailing related) 1 12-20-2000 05:05 PM
HTML code is Off
