Island Packet 35 - Page 2 - SailNet Community
 38Likes
post #11 of 63 Old 03-15-2019
Freedom Chip Counter
scubadoo's Avatar
Re: Island Packet 35
How's the project coming along? We're looking at an IP35 this weekend.....seen a few '89's over the past 2 weeks. Chainplate(s) and mast base access (for wiring) are my only two complaints. Everything else appears easily accessible...stuffing box is a bit tight though...full keel... There's a few videos (Mack Sails being one) out there on IP Chainplate replacement. They have a set fee for replacing all rigging and chainplates now. IP probably has the same thing right at the factory and is of course quite a bit closer to your location.
Any storm damage to the rudder or keel?
Keep us posted on your progress!
Best
krisscross likes this.
Tartan 31
scubadoo is offline
post #12 of 63 Old 03-15-2019
PhilCarlson's Avatar
Dock
Originally Posted by krisscross View Post
No, they are buried in. Im getting a rigger do that part, as well as the spreader repair.
A friend of mine, IP 31 owner, has been contemplating replacing his existing chainplates with hullside chainplates.
Not really sure if it's feasable, and it really changes the look of the boat, but you'd gain inspectability and access for maintenance. Something to consider.
capta likes this.
PhilCarlson is online now
post #13 of 63 Old 03-15-2019 Thread Starter
krisscross's Avatar
I have already replaced the chain plates for all 4 lower stays with external plates made specifically for island packet boats. They are incredibly beefy and are bolted through the ss bar which is glassed inside the hull during manufacturing process. But its a very expensive fix. The plates alone are about $500 each. And drilling 7/8 holes in 1/4 ss bar is no joke.
PhilCarlson and scubadoo like this.
Plato
krisscross is offline
post #14 of 63 Old 03-15-2019 Thread Starter
krisscross's Avatar
No storm damage to rudder or keel. Im almost done with the rigging, just waiting for an insulated back stay that had to be replaced. The work on rub and cap rails is moving very slowly as the weather has been wet and the carpenter slower than molasses in Siberian winter. Installed a new bow pulpit, and ordered a new port side cockpit railing which will include an 8 wind generator pole. I fixed the dodger and have all the parts for bimini which will have at least 2 solar panels mounted on top.
scubadoo likes this.
Plato
post #15 of 63 Old 03-15-2019 Thread Starter
krisscross's Avatar
Oh, and I had also completely re plumbed the head, making it fully compliant with Florida requirements.
Plato
post #16 of 63 Old 03-18-2019
scubadoo's Avatar
Thanks for the updates! We drove across the state to Bradenton and saw the IP-35 on Sunday. This is the 4th one we've looked at....they hold their value well.
Tartan 31
scubadoo is offline
post #17 of 63 Old 03-18-2019 Thread Starter
krisscross's Avatar
Yes, these are very well built boats that are also very comfortable to live on. Everything is really solid and IP factory workmanship is great. Before I bought this boat I drove over 3000 miles looking at over 30 different boats. It really was not such a hard choice. Even damaged, this boat stood out in a positive way against all the other boats I was considering. Yes, I am spending quite a bit of money and time on the repairs and upgrades, but I'm getting a boat that is really solid and will hold it's value should I decide to sell her.
Plato
post #18 of 63 Old 03-19-2019
roverhi's Avatar
The encapsulated chainplates in some IP's are a major concern if I was in the market for one. REALLY REALLY a danger of crevice corrosion when salt water gets in. Only way to find out if they've got it is wait for the chainplate to fail and the mast falls down. Converting to external chain plates shouldn't be that hard or expensive. The chain plates would be easy to fabricate out of 1/4" SS or thicker with a drill press and belt sander. It could be a do it yourself project though way easier to have a machine shop do it. Order the right width plate, cut to length, drill the holes for 3/8" fasteners get them electro polished and install using the original chain plates as backing. There hardest part will be drilling the holes through the old chainplates and cutting the tops off the old fittings.
roverhi is offline
post #19 of 63 Old 03-19-2019 Thread Starter
krisscross's Avatar
After digging around these chain plates I decided to only replace the plates for the 4 lower stays. They are made from a rather thin stock which does not look like 316. The PO did a nasty uncontrolled jibe and the boom slammed into the port aft lower stay kinking it on impact. Next day he noticed that the chain plate for that stay broke off at deck level. The new external plates are more than double in thickness. There is an outfit in Florida, neat IP factory which specializes in replacing chain plates on IP boats. They charge about 12 grand for replacing all the plates. I think its an overkill but the 4 lower stays definitely need to be replaced IMO.
Plato
post #20 of 63 Old 03-19-2019
Trailer Sailer Moderator
Rezz's Avatar
Congratulations on your new purchase! I'm looking forward to hearing about your progress and seeing pictures.
~ Rezz
S/v DreamWeaver
1980 Laguna Windrose 22
Rezz is offline
Island Packet 35 SouthernBreeze17 Boat Review and Purchase Forum 19 02-12-2018 02:02 PM
Looking for an Island Packet 35 - need help joeruncer Boat Review and Purchase Forum 1 10-04-2016 09:16 PM
island packet 35 brigadoonboat Boat Review and Purchase Forum 0 09-19-2009 08:24 AM
island packet 35 bobo Boat Review and Purchase Forum 14 01-29-2006 03:01 PM
Island Packet 35 Centerboard geyser Boat Review and Purchase Forum 1 07-22-2001 12:34 PM
HTML code is Off
