Island Packet 35 - Page 5 - SailNet Community
 38Likes
post #41 of 63 Old 04-27-2019 Thread Starter
krisscross's Avatar
Re: Island Packet 35
I appreciate the input. I'm definitely still learning.
Yes, sometimes I see the batteries go little bit under 12 V, like 11.9, in the morning. I know it's a bit under 50%. Also, the battery bank is getting old (7 years).
Plato
krisscross is online now
post #42 of 63 Old 04-27-2019
I would thumbnail 11.9 volts at 30% state of charge. Gels can take this better than any other, but it still hurts a bit.
If they're seven years old, you're due for replacement very soon anyway. If they're getting you through the day, just work on understanding the charging systems and prepare for a fresh new bank.
You want to read up on 3 stage charging profiles (bulk, absorb and float) and it's mandatory to have a shunt that can read amps going into your battery. Most basic monitors just measure what's being used or being generated by charge sources. However, as I said, what's actually going into your battery is usually very different.
All the best with your refit.
krisscross likes this.
Jeanneau 54DS
Minnewaska is offline
post #43 of 63 Old 04-27-2019
Seems likely that the current you are reading may be on the battery side of the controller (output) rather than the solar (input). 30 amps at 12 volts is 360 watts, which is certainly possible with 400w of modules.
Sent from my Pixel using Tapatalk
fmueller is online now
post #44 of 63 Old 04-29-2019
Take this with a grain of salt. I remember helping take a rudder off an IP-38 years ago. It SEEMS like it was fastened to the hull with what appeared to be "too small" 1/4-20 bolts. The rudder had become unshipped in a grounding. At the time, I was close to buying an IP-35, but someone beat me to it. I needed another boat like a hole in the head anyway. But that was the area on the IP that, to me, was of most concern. A relatively easily unshipped rudder and not a lot of meat in those 1/4 20 bolts.
VIEXILE is offline
post #45 of 63 Old 04-29-2019 Thread Starter
krisscross's Avatar
Thanks for the input. I will definitely take a close look at the rudder when I pull her out.
Plato
post #46 of 63 Old 04-30-2019
Freedom Chip Counter
scubadoo's Avatar
Maine-Sail has a great website on marine electrical installations...good article on SOC (State of Charge) here - https://marinehowto.com/under-load-b...oltage-vs-soc/
Tartan 31
scubadoo is online now
post #47 of 63 Old 05-01-2019
Administrator
Jeff_H's Avatar
Some years ago now, an acquaintance of mine was buying an Island Packet and asked me about something he observed on the boat. That boat seemed to have a bent rudder post and and the metal horizontal member that appears to support he bottom of the rudder was loose. When you turned the rudder that plate moved horizontally due to the bent rudder post. In researching the cost of repairs he spoke to several yards to get estimates. Quite a few of the repair yards mentioned experiencing and repairing this condition on a number of different Island Packets of different sizes and that this was a common problem on Island Packets on the Chesapeake. The comments from the boatyards was that these were essentially post hung rudders that had the metal fitting solely to keep lines out of the prop and to take some of the fore and aft forces on the rudder. But the design of the boats made the rudders extremely vulnerable to damage since the bottom of the rudder was so close to the depth of the keel that it was likely to receive an impact in a grounding and freeing.
The take away was that the typical Island Packet rudder was very vulnerable to damage in a grounding.
Jeff_H is online now
post #48 of 63 Old 05-01-2019 Thread Starter
krisscross's Avatar
While all that may be true, this particular boat was subject to a hurricane Michael boat pileup on shore and the rudder was undamaged, as verified by several above and under water inspections as well as subsequent 150 nm trip in the Gulf. The rudder and worm gear steering are really beefy. But I will be inspecting it very closely when I pull the boat out of the water.
RegisteredUser likes this.
Plato
post #49 of 63 Old 05-01-2019
Administrator
Jeff_H's Avatar
For what it was worth, when we were investigating the repairs to the boat I mentioned above, the consensus was that the worm gear was pretty beefy, but that the rudder post and bottom plate were not particularly all that robust.
post #50 of 63 Old 05-01-2019 Thread Starter
krisscross's Avatar
From what I can see, the rudder post is 2 diameter solid stainless steel. That seems pretty beefy to me.
Plato
Island Packet 35 SouthernBreeze17 Boat Review and Purchase Forum 19 02-12-2018 01:02 PM
Looking for an Island Packet 35 - need help joeruncer Boat Review and Purchase Forum 1 10-04-2016 08:16 PM
island packet 35 brigadoonboat Boat Review and Purchase Forum 0 09-19-2009 07:24 AM
island packet 35 bobo Boat Review and Purchase Forum 14 01-29-2006 02:01 PM
Island Packet 35 Centerboard geyser Boat Review and Purchase Forum 1 07-22-2001 11:34 AM
HTML code is Off
