Jeanneau Attalia - Page 28 - SailNet Community
 6Likes
post #271 of 281 Old 08-09-2015
JensK's Avatar
Re: Jeanneau Attalia
Dear Waymar
OK, thank you. Pretty much basics, but also showing that a lot of things have to be right to be in the front.
Keep up
JensK
Sailing in Denmark
Jeanneau Attalia
1986
31 feet
JensK is offline
post #272 of 281 Old 09-02-2015
Hi there everyone,
Congratulations Waymar to your success. I'm still working on mine...
As I told you about before our new mainsail was delayed, but we got it before the vacation. We're very satisfied with the new sails and rigg, although I'm still learning how to sail the boat as good as possible. I suppose (hope) that is a lifelong challenge.
I'm planning to buy a plotter this winter. We've been using an iPad with a navigational program called Seapilot. The program is good but it's difficult to see the charts in sunlight. I'm thinking about a plotter from B&G och Garmin. Do any of you have any ideas on what is good or not?
Jonas
Virgo is offline
post #273 of 281 Old 09-02-2015
Hi Waymar,
We changed to a new furling system for the genoa. Nowadays we have a Facnor Flatdeck which is very good.
/Jonas
Virgo is offline
post #274 of 281 Old 09-02-2015
Some pictures on Virgo with her new rigg.
Waymar83 likes this.
Virgo is offline
post #275 of 281 Old 08-12-2016
r1200gs_chris's Avatar
New to me Attalia being delivered next week. First order of business is replacing some of the sanitation lines. Can someone tell me how/where I access the waste holding tank? Thanks!
r1200gs_chris is online now
post #276 of 281 Old 09-04-2016
Hello again. Quick question on electrical issue with my new boat. Most of the interior lights have been upgraded to LED and occasionally they dim or go off and I cycle then house battery a few times and hey come back on. I've traced all of the wires and cleaned all contacts to no avail. I'm guessing it's an issue with the fuse panel. Can anyone comment on how they resolved this?
Sent from my SM-G870W using Tapatalk
post #277 of 281 Old 01-19-2017 Thread Starter
Not quite Senior Member
Waymar83's Avatar
Send a message via Yahoo to Waymar83
Hi Chris,
I'm not sure all holding tanks are in the same spot but my aluminum tank is in the cockpit locker closest to the head. There is a fiberglass cover that can be unscrewed and you have direct access to the tank and all the hoses.
Regarding the lights, if they dim or go off it, sounds like a problem of continuous current/voltage. Could be weak battery (I doubt its the fuse panel). Connect a voltmeter and monitor the voltage. If you have a fridge it could happen when the fridge cycles on and the voltage/current temporarily dips.
Mark
Now based in Barbados.... and wait for it.....the boat is too!
Waymar - Jeanneau, Attalia
Waymar83 is offline
The Following User Says Thank You to Waymar83 For This Useful Post:
r1200gs_chris (03-04-2017)
post #278 of 281 Old 06-06-2018
Hello Jeanneau Attalia owners. I have a 1986 model that needs the Cutlass Bearing replaced. The marina is having difficulty finding a replacement one. Does anyone know what model and where I can find one? I am located in Toronto in Canada.
Thanks
Stephane99 is offline
post #279 of 281 Old 06-08-2018 Thread Starter
Waymar83's Avatar
I’m away from my records right now but I had the same issue . The problem is that Jeanneau is in metric and what is available in Canada is not , so it’s ever so slightly off. I had one installed and it did not last long . If I recall, I sourced it similar to Beneteau and had it installed and it’s still perfect.
I’ll get back to you this weekend with more details !
Mark
Waymar83 is offline
post #280 of 281 Old 10-31-2019
Has anyone had any experience re-tourquing the keep bolts on their Attallia. Iím interested in seeing where to grind to expose the nuts/bolts and how much work this project is.
Sent from my iPhone using Tapatalk
attalia 32 1986 doros Jeanneau 2 03-04-2017 08:50 AM
Folding prop to Attalia Virgo Jeanneau 3 08-15-2016 08:50 PM
Another Attalia problem Ian38 Jeanneau 4 03-12-2012 06:22 PM
Attalia problem Ian38 Jeanneau 3 05-03-2009 07:15 PM
Jeanneau centerboard - Attalia rbrame Jeanneau 3 07-06-2008 12:10 AM
HTML code is Off
