Bukh DV10 General questions & inquiry - Page 2 - SailNet Community
 1Likes
post #11 of 24 Old 05-10-2017 Thread Starter
Re: Bukh DV10 General questions & inquiry
This is the GearBox (checked the oil, seems to be fine and plenty of it). By the way, what oil goes normally inside the engine and gear box?
PS: Gearbox seems to be BW6
flyrod likes this.
fgcity is offline
post #12 of 24 Old 05-10-2017 Thread Starter
Gearbox Image
I am assuming that is 2.5 Forward and 2.77 Back reduction ?
fgcity is offline
post #13 of 24 Old 05-10-2017
Page r3 in the workshop manual I linked in earlier post
knuterikt is online now
post #14 of 24 Old 05-10-2017 Thread Starter
Yes, thank you, i just downloaded it. Seems i need to go through that in a bit more detail Sorry for being annoying
fgcity is offline
post #15 of 24 Old 05-10-2017
My memory (often fading) tells me these are Dutch engines and are known as very reliable workhorses.
You may be gifted with a nice one that just needs some adjustments and care.
Being a single, it should be fairly easy to work on and diagnose problems.
Really, I would change all fluids and know cable adjustments should be reset, and maybe fresh cables needed. Stretched cables always need attention.
After you get her purring right, you can give her a name...
RegisteredUser is online now
post #16 of 24 Old 05-10-2017
Originally Posted by RegisteredUser View Post
My memory (often fading) tells me these are Dutch engines......
Dutch, Danish.... close enough
They are Danish, however. Yes, known to be reliable, but pricey parts when you can get them (not that they are alone in that).
Faster is offline
post #17 of 24 Old 05-10-2017
twoshoes's Avatar
Netherlandian and Denmarkian has always worked for me. Have extended family in Denmark that I visit from time to time. Nice place, try the herring. Try it 37 different ways.
twoshoes is offline
post #18 of 24 Old 05-11-2017 Thread Starter
Once again thank you all for the feedback. Really appreciate it. Am changing all that is leaking as well as adjusting it right now so it should work fine. (Not that it didn't before)
fgcity is offline
post #19 of 24 Old 05-14-2017 Thread Starter
Well i did a service on the engine. Changed Oil, cables, filters, changed and fixed the Thermostat. Seems to run just fine and after i lowered the RPM's a bit it does shift fine now from back to forth.
The oil in the gearbox is something i didn't change and from the documentation it looks like it uses the same oil as the engine but the level in the gearbox seems to be really high. Pretty much double of what the dipstick shows. I assume whoever pored it in, filled it up to the brim. I have limited access to the bolt to empty it so for few days will leave it as is.
One thing i did notice is a slight wobble of the shaft where the "Lubricating" coupling interfaces. The shaft i would say goes up and down about 1/4 of an inch. Is this something i should be worried about? I don't run the engine too high and mainly use it to get in and out of the marina.
fgcity is offline
post #20 of 24 Old 05-14-2017
Do you have an oil extractor (small vacuum pump/reservoir?) Easy to remove excess oil from the gear with one of those.
As to your shaft wobble, the first thing is probably to check your alignment - separate the coupling at the back of the gear and see how well the face-to-face surfaces match. The engine mounts should be adjustable to allow these faces to be trued up (be sure the shaft is centered in the log while checking this)
If you're unable to get a good alignment it's probable the shaft is bent - not a good thing long term, but by the sounds of it you don't have access to a lot of services. Machine shops nearby?? A new shaft may be necessary, that means a haulout and quite a bit of work (some boats the rudder needs to be dropped out before the shaft will pull free)
Just another in your list of 'to dos'.....
Faster is offline
General Questions- North Carolina LesSoldats General Discussion (sailing related) 8 03-18-2009 08:01 PM
Urgent Bukh Dv10 warwicksail Gear & Maintenance 9 01-12-2008 12:40 PM
few general crew questions buurz Crew Wanted/Available 8 10-25-2007 05:56 PM
Lots of General Questions jcook5003 Cruising & Liveaboard Forum 30 10-25-2007 05:08 PM
Headsail sheet - general length questions britcoal Gear & Maintenance 6 08-02-2007 04:43 PM
HTML code is Off
