Bukh DV10 Slow Throttle & Black Exhaust smoke - SailNet Community
 1Likes
post #1 of 12 Old 07-02-2017 Thread Starter
Hi everyone.
While i have been fixing up my Jeanneau Poker, i have been using the engine as my generator to run the power tools and other things.
When i initially got the boat a couple of months ago, it was (still is) in a pretty rough shape. The engine filters haven't been changed, belts needed replacement and some hoses leaking. The engine was running fine though.
So i did a small service, changed the filters, added an air filter, changed the oil and in general cleaned it up a bit.
The problem started though a couple of weeks ago. The engine while was starting before from firts try and right away, now needs few cranks to get going. Also dies few times before revs up.
The Exhaust now gives lots and lots of black smoke, which is lowered when the engine heats up but never goes completely away.
The throttle takes almost 10 seconds to begin revving after i actually pull the throttle lever.
Could someone tell me what is happening and what could be the cause for all this?
fgcity is offline
post #2 of 12 Old 07-02-2017
Dirt Free
boatpoker's Avatar
Re: Bukh DV10 Slow Throttle & Black Exhaust smoke
Does not sound good but always try the simple things first , remove the air filter you fitted, If it is non-OE it may be choking the engine. If that does not work it could be rings or injectors or injection pump ..... ouch !
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is offline
post #3 of 12 Old 07-02-2017
Master Mariner
capta's Avatar
Over-fueling is the primary cause of black smoke from the exhaust of a heavy duty diesel engine. Over-fueling can be caused by diesel fuel injector wear that enlarges the nozzle hole or erodes the injector needle and allows excess fuel to flow into the combustion chamber.
I think you probably had an injector fail. Not the cheapest fix, but at least its not a lot of work to pull and replace injectors. Pull them all and send them to a shop that specializes in them. Ask a big rig repair shop for the name of a shop and stay away from the 'marine' scene and save some money.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #4 of 12 Old 07-03-2017 Thread Starter
Tnx guys. Will check all possibilities. Hopefully i can have it back and running soon. My suspicion is the air filter though as it started once i installed it on.
fgcity is offline
post #5 of 12 Old 07-03-2017
JimsCAL's Avatar
It sounds like you have been running the engine at low load for extensive periods. Diesels don't like that. If you don't have power where you are working on the boat, better to get a small portable generator.
One thing to check is the exhaust elbow. Your extended period of low power running may have plugged it up with carbon deposits.
oysterman23 likes this.
S/V First Tracks
1985 Cal 33-2
JimsCAL is online now
post #6 of 12 Old 07-07-2017 Thread Starter
I removed the air filter and not much changed. I did find a used pump and injector but before i go ahead and bu those, could all this be caused by too much oil?
I did pour more than needed and i can see oil patches (not as much oil as stains filling up around the boat) when i try to start it.
Could the throttle slow response (almost non existent at the beginning) and the smoke be cause by too much oil? All this started after i serviced the engine.
fgcity is offline
post #7 of 12 Old 07-09-2017 Thread Starter
Well, i removed almost a liter of oil from the engine as it seems i overdid it.
The smoke is very minimal now and only at the start when it is cold. It does take few more cranks to get it going but when it does the throttle response is fine now. I filled the tank with some injector cleaner to clean the internals a bit.
I remember that the engine was starting before from first try with very little effort before. Not sure why it isn't now but i did notice that the Return line which is coming from the fuel filter was going into the tank into a port which didn't have a hole. Perhaps the pressure was building up and was starting faster. Fixed it now so the excess fuel leaks back into the tank as it should.
Ordered also a spare fuel pump and injector just in case.
fgcity is offline
post #8 of 12 Old 09-12-2017
And be very careful about running the engine as a generator (risk of carbon monoxide). There have been a number of cases in the UK where there have been deaths caused on boats by CO poisoning whilst the engine has been running, but the boat stationary, but battery -charging, etc. (Google "MAIB" (Marine Accident Investigation Branch) and "Vasquez", or "Love for Linda" for 2 most recent cases, but there have been others).
Andrew
ParkstoneBay is offline
post #9 of 12 Old 09-13-2017
1) Diesels thrive on hard, constant work that keeps them up to working temperature for most of the time. What they don't like is frequent start-stops, brief periods of operation, rarely reaching design operating temperature, living in a cold, moist atmosphere and infrequent oil changes.
2) Black smoke from exhaust Cause is incomplete fuel combustion. Can be due to injector problems, high load, poor compression and valve wear.
3) A further cause, when black smoke is accompanied by a severe reduction in maximum revs, is blockage of the exhaust manifold/exhaust risers by salts and or carbon build up.
4) Over filling any engine (especially diesels) with oil is dangerous, The normal oil level should only be between the low and full marl (Never Over)
Steve
Captsteve53 is offline
post #10 of 12 Old 09-27-2017 Thread Starter
Well it wasn't any of those issues but something more drastic.
The one valve was sticking as a result of bad cylinder head gasket. The valve froze, bent the pushrod and the engine stalled.
The people at TW Marine were kind enough to send me a refurbished valve head, new valves, the gasket kit and i also replaced the water pump seals as that may also caused the water to come in. Changed the piston rings just in case, cleaned the whole thing and put it together.
Rebuilt the engine in a day and it purrs like a kitten now.
Also installed a Vetus Exhaust system so the water goes into the box and doesn't just sit inbetween the engine and the outlet. Hopefully this will be the last of my problems as the engine runs like new now. Almost am afraid to have it running now
fgcity is offline
Bukh DV10 General questions & inquiry fgcity Jeanneau 23 05-14-2017 02:24 PM
Yanmar 3GMD unburnt fuel/ black smoke/ Exhaust bronk33 Diesel 14 11-11-2014 07:20 PM
Yanmar - black smoke in exhaust JSL3 Diesel 18 07-20-2009 12:23 PM
Black smoke and black water bruceyp Gear & Maintenance 25 08-04-2008 01:00 PM
Urgent Bukh Dv10 warwicksail Gear & Maintenance 9 01-12-2008 12:40 PM
HTML code is Off
