Jeanneau Poker 28ft - Raw Water intake too high? - SailNet Community
 1Likes
  • 1 Post By Faster
post #1 of 3 Old 10-22-2017 Thread Starter
Hi everyone,
I just finished working on the Bukh DV 10 engine and seems everything is working fine.
However, the problems i had were related mostly to the head overheating and cracking. So i cleaned the Raw water intake for the engine and it draws water fine now.
But while cleaning the intake through hole seems to be really high. I mean i it almost at the waterline (2 cm below it) so i wanted to ask, is this normal?
I noticed that when sailing, the boat goes up and down and the water seems to draw some air every time it does it. Is this in general normal?
My through hole is on the back of the boat on the left side where the seats are, just near the fuel tank i installed. So i just wanted to ask if this position for the trough hole is normal for cooling.
fgcity is offline
post #2 of 3 Old 10-22-2017
Re: Jeanneau Poker 28ft - Raw Water intake too high?
It is most common for thru-hulls to be down low and close to the center, to allow for heeling. Although, most owner's manuals identify a max heal angle to run the main engine or generator and cooling intake is one of the limiters. I don't know if that's a normal location for yours, although, it would be pretty odd that someone relocated it.
When you say you cleaned the intake, it sounds like you cleaned the thru hull itself. Was it particularly clogged? If you were overheating, you should be as concerned with either the cooling passages in the motor, if raw water cooled, or the heat exchanger, if fresh water cooled. These will corrode and close over time. Some require disassembly, others can be cleaned by circulating a descaler.
Jeanneau 54DS
Minnewaska is offline
post #3 of 3 Old 10-22-2017
A RW intake that close to the water line makes no sense, and indeed wave action and heeling will occasionally let the pump suck air.. not good for your already-prone-to-temp-issues engine.
I'd take a serious look at moving it.
Deina likes this.
Faster is offline
Jeanneau Poker 28ft - Teak Deck Fix or Remove? fgcity Jeanneau 28 11-18-2017 12:23 PM
Jeanneau Poker 28ft - Nose futting fgcity Jeanneau 0 07-09-2017 12:47 PM
Jeanneau Poker 28ft - Spreaders fgcity Jeanneau 17 05-15-2017 11:12 AM
Jeanneau Poker 28ft - Does it have a Bilge? fgcity Jeanneau 3 05-07-2017 12:32 PM
Additional raw water intake to supplement saildrive intake. GMC Gear & Maintenance 1 02-18-2012 03:10 PM
HTML code is Off
