Starfisher ST670 - SailNet Community
post #1 of 3 Old 09-05-2018 Thread Starter
Starfisher ST670
Hi guys in some desperate need of help i have lost my propeller and don't know the standard size fitted from new, all I know it was 4 blade bronze fixed proppeller on a 30 mm 1:10 tapered shaft , my engine is volvo penta TAMD 22P 105hp. Why can't I find this information ? Can anyone help ?
Sent from my SM-G935F using Tapatalk
dx575 is offline
post #2 of 3 Old 09-05-2018
JimsCAL's Avatar
Re: Starfisher ST670
If you can't find out what the original prop was, any prop manufacturer or prop shop will be able to size one for you.
S/V First Tracks
1985 Cal 33-2
JimsCAL is offline
post #3 of 3 Old 09-05-2018
Master Mariner
capta's Avatar
Every prop manufacturer should have a chart online which should give you a close fit. After that, your local prop shop can't tweak it a degree or two to get it spot on. You will also need to know the gear ratio on your trany.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
HTML code is Off
