Garmin and Polar View ??? - Page 2 - SailNet Community
post #11 of 16 Old 12-30-2014 Thread Starter
Yo no soy marinero.....
Flint's Avatar
Talking Re: Garmin and Polar View ???
Wow, that's excellent news!! Thank you.
I have just downloaded Garmin Spanner and will install it on the test machine after work.
When the sailing season returns I have an older 12" XP laptop that will be dedicated to this job. I have previously known how to assign virtual serial ports from within Windows - its been a while and I just can't remember the sequence.
Part of the reason for picking the Montana was that it was recommended by Garmin for marine use, could be interfaced, its not only water proof - and It Floats!!!
I will give this a try this evening and report back.
Thanks guys
David
Flint is offline
post #12 of 16 Old 12-31-2014 Thread Starter
Flint's Avatar
Thumbs up Re: Garmin and Polar View ???
Fantastic!!!
Garmin Spanner loaded and cofigured seamlessly; Polar View connected using its port manager; select Live Mode and the system found me even at
N6922.555'
W8148.035'
Absolutely awesome! I'm going to put it through some paces, see how it works with the GPS in simulation mode on some of the NOAA charts of Lake Ontario.
cheers
David
The Walrus, Collins Bay, Lake ON
Flint is offline
The Following User Says Thank You to Flint For This Useful Post:
eherlihy (12-31-2014)
post #13 of 16 Old 12-31-2014
Learning the HARD way...
eherlihy's Avatar
Thank you for the follow up report!
USCG Licensed OUPV Captain, US/Sailing BKB and ASA 101/103/104/105/106/114/118 Instructor - Also ABYC certified in Marine Electrical Systems,
eherlihy is online now
post #14 of 16 Old 12-31-2014
TakeFive's Avatar
I am glad that it's working well for you.
I looked a little closer at the Montana specs, and that's a REALLY NICE handheld. Definitely a good next-generation follow-up to the Oregon, with bigger screen and better daylight viewability. However, be careful with it around the water, because I believe that it does NOT float. (Neither does the Oregon.)
I never liked plotting routes on the Oregon - it's just too small. It's much nicer to plot on the computer and transfer to the handheld for use on the boat. I've done this with OpenCPN, and if Polar products will save in .gpx format, you can transfer them. However, it's not as simple as just copying the .gpx file through USB. You need to load it into Garmin PC software and use their software to put it in the device. I bought HomePort to do this, but I believe that their free BaseCamp software will do it also. Give yourself a couple hours to figure it out, because the user interface of all Garmin's PC software really sucks.
If you're trying out free PC software, I'd recommend also trying OpenCPN in addition to PolarView. It has really advanced in features, and will be launching version 4.0 in a week or so. I like it so much that I installed it on a tablet that I mounted in my cockpit as my primary chartplotter. I still use the Oregon to record my tracks, and as a wet weather backup.
Rick S., Swarthmore, PA
USCG Certified Captain, OUPV and 50 Ton Master
2001 Catalina 34MkII Tall Rig Wing Keel Breakin' Away, Universal Diesel M35B, Mantus 35 lb. anchor, sailing out of Rock Hall Landing Marina
TakeFive is offline
post #15 of 16 Old 01-02-2015 Thread Starter
Flint's Avatar
Good thing then I didn't rely on it floating. I got it with the marine bulkhead mount so will keep it well secured. The Montana is more like operating your tablet or smart phone. A wide variety of useful applications, most of those apps can be nested into each other in the "Dashboard" feature. So you can quickly toggle back and forth to from Map to Compass. The home-screen can hold most needed icons like "Mark" "MOB" "Where to", while at the same time displaying lots of user selected data in its header.
I'll probably mount it high on the bulkhead and a small XP laptop on an elbow mount, perhaps just inside the companionway.
Simulation mode seems to be entirely internal and does not send data to the serial port.
Even for the $50 Polar View works well. I'll definitely check out Open CPN, thanks. I'm a bit of a tech geek so no doubt I'll be looking for a way to get the system to run the AutoHelm next.
Flint is offline
post #16 of 16 Old 01-02-2015
TakeFive's Avatar
If you have a leftover XP laptop that you want to repurpose, that's fine. Get a sturdy RAM mount for it.
If you're buying new, I'd suggest a Win8 tablet. Much lighter, better form factor, and tapping icons on a touchscreen is much nicer than moving a mouse cursor with a trackpad. Some of them have internal GPS, so you might not need to run Spanner. There's a whole lot of discussion of this over on the OpenCPN forum - and a few threads that I've posted here. Let me know if you want links. It's too late for me to dig them up now.
By the way, OpenCPN can run my Autohelm in track mode. In my case it's done wirelessly via Bluetooth. There's a really geeky thread here telling how I did the hardware setup. I plot the route in OpenCPN, and the Win8 tablet sends the waypoint information to the autopilot. It can do a whole multi-point route, but more frequently I will just tap a location on the chart, select "navigate to here," and the autopilot will do a straight line route to the waypoint. In lumpy seas, the boat's heading seems to stay more stable in this mode than trying to maintain a constant heading, where the sea oscillations can cause the heading oscillations to get larger over time (despite adjusting the gain). The explanation is complicated, and gets into PID control theory.
TakeFive is offline
Tags
garmin , gps , interface , polar view , software
Good Deal (Polar View) from Active Captain rockDAWG General Discussion (sailing related) 17 06-28-2016 01:26 PM
Polar Diagrams sandycohen Racing 18 05-27-2014 01:38 PM
Polar Tables rbonnin Racing 6 12-09-2012 03:29 PM
C 27 TR Polar Chart Mark1948 Catalina 2 08-08-2012 11:17 PM
looking for polar data odins701 General Discussion (sailing related) 1 06-05-2009 06:46 PM
