ASA 101 Prep? - Page 2 - SailNet Community
 9Likes
post #11 of 19 Old 07-17-2015
Old enough to know better
Re: ASA 101 Prep?
I have heard a couple lessons from this guy:
https://itunes.apple.com/us/album/sa...ign-mpt=uo%3D4
I have mixed feelings on it. He has some samples on his podcast at Sailing in the Mediterranean and I would listen to the sample, but the set for 101 is only $10. Not sure if I would want to listen to him for money, but his pod cast can be interesting, but not great. But if you have a commute it might be better to listen to than the "morning gang" on any radio station. Might be a good additional source. I think he tends to editorialize and criticize what is expected to be known for my taste. I understand some of the info and terminology may be arcane, but you just learn it and go on.
miatapaul is offline
post #12 of 19 Old 07-17-2015 Thread Starter
Re: ASA 101 Prep?
Originally Posted by WrkdbfGuy View Post
I have the ASA 101/103 classes coming up in about three weeks. My books have already arrived and I'm reading them carefully. Make sure your class sends you your material. It seems logical to me to get the "book stuff" out of the way so the "on the water" time can be spent wisely.
Bill
Getting my materials on Monday, and reading the Annapolis Book of Seamanship in the meantime. Thanks to everyone for the good advice, really excited to take the next step toward my own boat.
dirtloves is offline
post #13 of 19 Old 07-17-2015 Thread Starter
Re: ASA 101 Prep?
I do have a commute, but it's by boat so I spend it looking at the water mostly :-)
post #14 of 19 Old 07-17-2015
Re: ASA 101 Prep?
Good luck & have fun! I took the 101 challenge, & the admiral did the 101-104 course in April. As others have said, read the book & be able to understand / answer the review questions. Hopefully the course weekend will strengthen your sailing desires & abilities.
Mike
Summmitfun is offline
post #15 of 19 Old 07-20-2015
Minnesail's Avatar
Re: ASA 101 Prep?
That is a fantastic book. It has everything the ASA books cover plus much more. I went through it cover to cover (OK, I skimmed some of the nav stuff) when I first started sailing, then went through it again when I took ASA 106 and they used it as the course book.
Catalina 22
on a starboard tack
Minnesail is offline
post #16 of 19 Old 07-20-2015
Re: ASA 101 Prep?
Let's not forget that ASA 101 is a beginners's course. It includes the fundamentals, and assumes you know nothing. The class I took was structured so that classroom was in the morning, and we tried stuff out on the water in the afternoon.
There is no need to study before the class. It would be useful to review the day's material in the evening after the class, and definitely swot up before the test!
MarkSF is offline
post #17 of 19 Old 07-20-2015 Thread Starter
Re: ASA 101 Prep?
Definitely true, but I figured if i can shorten classroom/shore time, all the better!
post #18 of 19 Old 07-22-2015
Re: ASA 101 Prep?
I will give a "chalk talk" at the outset, but if everyone has studied either a book or an on-line tutorial, or even just looked at the standard Points-of-sail circular diagram, I can make the talk-time shorter and sailing time longer.
But I do not assume anyone has read or studied anything, I'll ask them, and ask about any prior sailing experience no matter how long ago.
I think the bigger question here is about learning styles and how they mesh with teaching styles. I tend to think sailors learn better by sailing, then looking afterward to see how "the book is right", than reading the book and comparing their experience to it--almost too much to think about when it's all new. So I'm more likely to give a short "debrief" with (my beat-up) book afterward if they have time, showing them how much of the book they just did. I think it leaves them on a high note.
I could be wrong doing "do, then read about it", if someone's learning style is the opposite, but haven't seen a downside in actual practice.
Reading beforehand is fine, just don't let it make you nervous or intimidated. Sailing is easier than you will expect..
nolatom is offline
The Following User Says Thank You to nolatom For This Useful Post:
dirtloves (07-22-2015)
post #19 of 19 Old 07-22-2015 Thread Starter
Re: ASA 101 Prep?
That all sounds excellent. Sounds like I'm letting my excitement get out of hand. :-)
ASA 101 course or challenge? itsaboat Learning to Sail 25 04-01-2012 06:57 PM
ASA 101. Hell yes. RatHatDiver Learning to Sail 22 08-11-2011 11:13 PM
Took ASA 101, looking for next step guinsu Learning to Sail 6 08-25-2008 03:21 PM
Just Completed ASA-101 cnbnichols Learning to Sail 5 08-11-2008 06:40 PM
ASA 101 Exam MauritiusDiver Learning to Sail 3 08-08-2008 01:17 AM
