Sailing jib and spinnaker at the same time - SailNet Community
 3Likes
  • 1 Post By AKMac
  • 1 Post By Faster
  • 1 Post By jackdaw
post #1 of 10 Old 12-09-2016 Thread Starter
This is probably a dumb newbie question, but I have searched and can't find an answer.
I know very little about sailing. I've never even sat foot on a sailboat. However, the thought of selling all my possessions, quitting my job, and sailing is very temping (especially during those bad days at work!) If nothing else, my wife and I might buy a small boat such as a catalina 22 and sail it locally in Utah. This said, I have read a book (sailing for dummies) and have watched many hours of sailing on youtube. (SV Delos, Sailing La Vagabond, Catamaran Impi, SV Seeker, and Gone with the wynns are my favorites.)
My question is this. Is it ever desirable or even possible to sail a jib/genoa and a spinnaker at the same time? Or would the jib create a "shadow" on the spinnaker leading to poor performance?
Like I said, probably a dumb question, but I've never seen it discussed. Thanks!
grumpyolddude likes this.
AKMac is offline
post #2 of 10 Old 12-09-2016
Re: Sailing jib and spinnaker at the same time
It is done on occasion.. for example the Aussie 18 skiffs always sailed with both; mainly because the apparent wind is always so far forward that the (small) jib actually may help a bit, that and the downwind legs were so short there probably wasn't time to douse and reset..
Boats that never really sail 'deep' (dead down wind) will have more success. Smaller jibs work better than genoas. In the 70s and 80s a lot of IOR boats flew a spinnaker staysail, a very skinny 'jib' tacked to the mid foredeck.
One upside of having a jib up then is you'll generally avoid wrapping the forestay with the spinnaker, but the spinn may not be as stable.
Most casual downwind/spinnaker sailors will rarely fly both together...
RichH likes this.
Faster is offline
post #3 of 10 Old 12-10-2016
Master Mariner
capta's Avatar
Unless you are racing, why would you even want to? Flying a chute with only one or two aboard is enough of a handful should things get a bit dicey, without having another head sail to contend with.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #4 of 10 Old 12-10-2016
paulk's Avatar
Every boat is different, and each time you set out in it is different too. For some boats, jib & spinnaker at the same time is normal. For others it doesn't usually happen, but could. It depends on the boat and the conditions. The jib might blanket the spinnaker depending upon your heading or the windspeed, or it might not. It might have a big effect or it might not. It might be too much to handle or it could be no problem. Everything on a boat changes all the time.
paulk is offline
post #5 of 10 Old 12-10-2016
mf70's Avatar
On my ketch, it's a normal option for a broad reach that will last a while. If done, it'll usually have one reef on the inside sail to minimize blanketing.
Sent from my GT-P3113 using Tapatalk
"Sanderling" 32' Sharpie Ketch
mf70 is offline
post #6 of 10 Old 12-12-2016
Anarchist in Exile
For fast boats (J/70, J/111, Class 40, Volvo, Vendee, etc), this is easy.
If you're planing, leave the jib up.
If you're not, take it down.
When you are planing the boat speed pushes the apparent wind goes so far forward it makes the jib effective.
RichH likes this.
Navigare necesse est, vivere non est necesse.
jackdaw is offline
post #7 of 10 Old 12-12-2016
RichH's Avatar
almost ditto. A small jib used as a staysail 'under' a spinnaker on a planing hull boat will create a larger amount and with a change in apparent (favorable) incidence angle of the oncoming upwash for the spinn to operate in; and, if the staysail is trimmed to perfection (draft forward shape with 'rounded' luff entry shape via increased halyard tension) will/may favorably enhance the apparent wind 'to' the spinnaker ... for increased spinnaker efficiency and 'higher'/faster apparent course angle sailed.
The same applies for cutter rigged boats with staysail under a 'top sail'; but, the normal staysail must be 'reshaped' (draft forward and w/ rounded luff shape ... via changes in halyard tension) and precisely trimmed according to the speedo.... very 'finicky'.
RichH is online now
post #8 of 10 Old 12-12-2016
Broad Reachin'
kwaltersmi's Avatar
Depends on crew, boat and wind angles. But on our boat, we only ever have them both up at the same time if we need to wind shadow the spinnaker to get it down easier.
Catalina 34
kwaltersmi is offline
post #9 of 10 Old 12-12-2016
Barquito
Barquito's Avatar
ditto, ditto on RichH. Rich has mentioned Avrel Gentry's wonderful articles on sail theory in the past. One concerning double head sails is located here:
http://www.ftp.tognews.com/Publicati...e_Head_Rig.pdf
Valiant 32
Barquito is online now
post #10 of 10 Old 12-12-2016
Anarchist in Exile
Indeed, CAN be a help when reaching, IF trimmed very well! So often you hear comments about this from a boat sounding like: 'We gained speed when we put the jib back up, and gained speed again when we took it down!'
jackdaw is offline
Jib vs Genoa vs Spinnaker eagles_dare13 Learning to Sail 13 09-30-2015 07:25 PM
Using Jib and Genoa at the same time to create spinnaker Zac Penn Learning to Sail 14 12-22-2013 08:57 PM
Spinnaker halyard for a furling jib?? sfbaysailing General Discussion (sailing related) 13 04-06-2012 01:55 PM
Using spinnaker pole to pole out jib when sailing downwind... sweetdreamyamaha Seamanship & Navigation 5 09-08-2010 11:39 AM
Flying an undeclared oversized jib as a spinnaker mikehoyt Racing 4 06-17-2004 05:49 AM
