sailing past close hauled? - Page 6 - SailNet Community
 58Likes
post #51 of 85 Old 02-18-2019
Moderator
Arcb's Avatar
Re: sailing past close hauled?
I dont think i would want a keel on SanderOs theoretical boat. I think light and fast would be the way to go,maybe a tri, maybe foiling. Higher apparent wind speed, less hull in the water, less drag, no big hunk of lead to cart around. I still dont think you could sail straight upwind though. I dont think the technology currently exists to overcome all drag.
SanderO likes this.
Arcb is offline
post #52 of 85 Old 02-18-2019
SanderO's Avatar
This may be true... water drag is much more than air drag... so yes very slick and small underbody would be in order. And you DO need a lot of apparent wind. But it is amazing how little wind can get a multi ton vessel moving.
pay attention... someone's life depends on it
SanderO is online now
post #53 of 85 Old 02-18-2019
Originally Posted by SanderO View Post
Minni I think you are not understanding this though experiment. I encourage discussion not an argument.
A vertical mast w/ sail when sailing close to the wind... generates a small vector more or less forward. ....
Draw the cord of the sail, when close to the wind, then draw the same cord on a horizontal wing. You'll see the difference.
The vertical sail/wing is at a very different angle of attack (especially when close, but not directly into the wind) from your theoretical horizontal wing in relation to the forward direction of the vessel.
Jeanneau 54DS
Minnewaska is offline
post #54 of 85 Old 02-18-2019
SanderO's Avatar
How about this... what would the impact be on how your sloop would sail of you could can't the mast (tip it at its base) to one side or the other. Would you kill your ability to point and make more leeway? I think so if it is tipped to leeward. If it is tipped to windward what would happen? stall?
post #55 of 85 Old 02-18-2019
SanderO's Avatar
correct.... but why can't the horizontal sail be rotated? It can... the chord can be any angle... not all will work of course... the luff has to be... should be higher than the leach. no?
post #56 of 85 Old 02-18-2019
A glider moves forward doesn't it?
Yes, but not for free. It has potential energy in the form of altitude. Its moving forward because its running down hill.
eherlihy and SanderO like this.
CrispyCringle is offline
post #57 of 85 Old 02-18-2019
Learning the HARD way...
eherlihy's Avatar
A glider would not work without gravity.
USCG Licensed OUPV Captain, US/Sailing BKB and ASA 101/103/104/105/106/114/118 Instructor - Also ABYC certified in Marine Electrical Systems,
eherlihy is online now
post #58 of 85 Old 02-18-2019
SanderO's Avatar
how does it get up the hill in the first place?
post #59 of 85 Old 02-18-2019
SanderO's Avatar
actually I think a glider wouldn't work without apparent wind. And a glider works with thermals... but apparently can travel forward 60 miles and drop 1.
post #60 of 85 Old 02-18-2019
You're starting to follow my point. On your horizontal wing sail, directly into the wind, the luff would be slightly higher than the leach, ie the cord indicating the leading edge is slightly higher than the trailing edge, relative to the forward vector of the boat. This is exactly the opposite of a vertical sail on a close haul. Sketch them out. The perpendicular of the cord is pointing aft, not forward like a sail.
SanderO likes this.
Jeanneau 54DS
Why buy a steel hulled sailboat? ColoGuy Cruising & Liveaboard Forum 6 03-05-2017 06:41 PM
AB aluminum hulled RIB speciald Gear & Maintenance 2 01-11-2009 08:40 PM
The optimum close hauled to close hauled tack davidpm Racing 20 07-08-2008 07:23 AM
Glass hulled Wooden Boats JakeLevi Boat Review and Purchase Forum 5 11-01-2006 06:13 PM
Inexpensive Wooden hulled Boats? Grauadler Boat Review and Purchase Forum 2 12-26-2002 11:03 AM
