sailing past close hauled? - Page 7 - SailNet Community
 58Likes
post #61 of 85 Old 02-18-2019
Re: sailing past close hauled?
Originally Posted by SanderO View Post
how does it get up the hill in the first place?
A glider gets uphill in the first place because it's towed by an airplane with a motor.
Sailormon6 is online now
post #62 of 85 Old 02-18-2019
SanderO's Avatar
Originally Posted by Minnewaska View Post
You're starting to follow my point. On your horizontal wing sail, directly into the wind, the luff would be slightly higher than the leach, ie the cord indicating the leading edge is slightly higher than the trailing edge, relative to the forward vector of the boat. This is exactly the opposite of a vertical sail on a close haul. Sketch them out. The perpendicular of the cord is pointing aft, not forward like a sail.
But regardless you can develop a forward vector. It may not be enough to overcome friction... but it does in a sloop rig... which is at most 30 off the eye of the wind.
pay attention... someone's life depends on it
SanderO is online now
post #63 of 85 Old 02-18-2019
You really need to sketch out the cord vs forward direction of the boat. The perpendicular to the cord of a vertical sail is forward of the beam in all points of sail up to close hauled. In your theoretical horizontal wing, directly into the wind, it's not. Same would be the case for a vertical sail, if it could magically hold shape, with the boat pointed directly into the wind.
Jeanneau 54DS
Minnewaska is offline
post #64 of 85 Old 02-18-2019
SanderO's Avatar
Ok
post #65 of 85 Old 02-18-2019
Captain Obvious
Sal Paradise's Avatar
No Sanadero, you are wrong. The plane descends - this is where the energy for forward motion comes from. The wing actually produces a horizontal vector backwards, in the form of drag.
Sal Paradise - Armchair Circumnavigator
Senior Researcher - Dunning Kruger
Sal Paradise is offline
post #66 of 85 Old 02-18-2019
It must use a perpetual motion engine of some type. Got me there.
Im being sarcastic. Sorry. But this thread is sort of going off the rails with crazy theories and misunderstanding of how stuff works.
CrispyCringle is offline
post #67 of 85 Old 02-18-2019
I usually apply the Dunning Kruger Effect while attending my morning entertainment of SN.
Capt Len is online now
post #68 of 85 Old 02-18-2019
Moderator
MarkofSeaLife's Avatar
Dock
We don't do that on Sailnet.
Believe it.
No one here is an idiot.
SanderO likes this.
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #69 of 85 Old 02-18-2019
Minnesail's Avatar
My wife and I saw a production of Shakespeare's "As You Like It" on Saturday night, which includes Touchstone's line:
The fool doth think he is wise, but the wise man knows himself to be a fool.
JoCoSailor likes this.
Catalina 22
on a starboard tack
Minnesail is offline
post #70 of 85 Old 02-18-2019 Thread Starter
Re: sailing past close hulled?
I think of the sideways vector being countered by the keel, not summed, leaving the forward vector to propel the boat. Some keels do a better job of this countering and have less leeway, as a result.
The OP might think of these vectors this way. As you come up on the wind, the sail must be moved closer to the center of the boat. This makes the sideways vector grow and the forward vector decline (also the reason for heeling). Even if you could maintain sail shape right up to dead on the wind (which of course you can't), you would only have side vector and no forward vector. Certainly, as you even approach this mythical point of sail, the forward vector diminishes to the point that it won't overcome the friction of the hull anyway.
Originally Posted by CrispyCringle View Post
The simplest way I can explain this is, the lift vector produced by the sail only really points in one direction, roughly leaning a little forward of perpendicular to the boom when into the wind. Most points of sail are using only a fraction, or component of that lift. You cant just point the boat straight into the wind and pull the boom over past center because then the lift vector now has a component pulling you in reverse of the direction you want to go. There is no forward component left to give.
As stated by Minnewaska, then the resultant vectors gives no forward motion as you point the boat higher even if the sail is kept in trim, vectors cancel out and the forward vector is about zero. All you have is side vectors. Thank you, and the picture is what I was trying to describe; a boat point dead into the wind, but the sail still trimmed way past the center of the boat to prevent stall (still creating lift). All you would have left is sideways motion, not forward. Thanks again.
1988 C&C 30MkII used as a live aboard in MD. Sailing experience: Started 2014; 6-mo on Hobbie Cat Wave 13', 1 year on a Potter P15 sailboat, and ASA 101,103/104 classes. Power boater for 20+ years.
serpa4 is offline
Why buy a steel hulled sailboat? ColoGuy Cruising & Liveaboard Forum 6 03-05-2017 07:41 PM
AB aluminum hulled RIB speciald Gear & Maintenance 2 01-11-2009 09:40 PM
The optimum close hauled to close hauled tack davidpm Racing 20 07-08-2008 08:23 AM
Glass hulled Wooden Boats JakeLevi Boat Review and Purchase Forum 5 11-01-2006 07:13 PM
Inexpensive Wooden hulled Boats? Grauadler Boat Review and Purchase Forum 2 12-26-2002 12:03 PM
