Lowering the boom - Page 2 - SailNet Community
 2Likes
post #11 of 17 Old 2 Weeks Ago
outbound's Avatar
Re: Lowering the boom
Youíre right of course. Didnít think it through.
s/v Hippocampus
Outbound 46
outbound is online now
post #12 of 17 Old 2 Weeks Ago Thread Starter
hpeer's Avatar
Jeff,
I think I know what you mean by “the appearance of an ease.” I will pay attention to that next time, see if I can do better.
I’ll report back after our next sail. A few days.
33' Brewer, Murray 33, steel cutter
44' Pape, Steelmaid, cc steel cutter
hpeer is online now
post #13 of 17 Old 2 Weeks Ago
Administrator
Jeff_H's Avatar
If it is any consolation, I first thought "hey, I forget to mention the Cunningham." before I had my "never mind" moment.
Jeff_H is online now
post #14 of 17 Old 2 Weeks Ago
al brazzi
More twist on the main would help with the jib reefed, hard to do without a traveler, or as mentioned with Vang eased traveller (or other means) pulled higher sheet eased, will let the head twist off. The air up there is not doing the same thing the air down here is. Cunnungham moves the draft forward, doesn't look like that would hurt. Usually done as a small depower before reefing, depends on where you usually reef, all Boats are different. My Boat likes to be reefed sooner than I do it, usually.
The simplest most effective main sheel I ever used was a triangle, only one sheet. Had its drawbacks but you couldn't pull it so tight (without a winch) to stall the head, but it couldn't be pulled up to center to get truly close hauled.
albrazzi is offline
post #15 of 17 Old 2 Weeks Ago Thread Starter
hpeer's Avatar
I fussed with the sail today on anchor.
1. Loose. Main sheet and gang
2. Tighten outhaul.
3. Raise the main.
I got the sail to the top of the mast and I was lifting the boom a good bit. I was doing the right things but in the wrong sequence.
Here is the sail now. At anchor, no tension on the main sheet, about 15 knots.
To me it looks better already.
PhilCarlson likes this.
hpeer is online now
post #16 of 17 Old 1 Week Ago Thread Starter
hpeer's Avatar
Feedback...
I messed with the sail as Jeff suggested. Jeff, your suggestions made perfect sense and I now feel stupid for coming to them on my own. Brain got stuck in some repetitive rut!!
I also added some low friction rings to the cringle s, makes setting reef foot tension much easier.
I’ve only a couple of trips with her now but there is a marked improvement in her speed and Windward progress. I also need to adjust when I rest, make it sooner. St Vincent to Bequai the other day, 15 - 20 apparent in both owe reach to 60į on the wind, and I had to really deposed the sail a LOT to keep her in her feet. Doing about 6-1/2 knots, which is pretty good for 40,000# on 37 LWLi think. I would have putnin a second reef if it were not such a short trip.
I’m now seriously considering having a third reef point added this summer during layup. Easy to see how it could be real useful.
Thanks to all for the help, got me out of my stupor. The learning goes on.
hpeer is online now
post #17 of 17 Old 1 Week Ago
Administrator
Jeff_H's Avatar
I am glad to hear that it worked out for you.
Lowering a deck stepped mast Zephyrzen General Discussion (sailing related) 17 12-21-2010 03:02 PM
Tips on lowering sails sailguy40 Learning to Sail 18 06-16-2010 12:18 PM
mast raising and lowering divicolouis Gear & Maintenance 5 08-08-2003 10:08 PM
Rhodes 22 mast lowering under bridge GeneStory Gear & Maintenance 1 10-20-2001 08:48 PM
Lowering a deck stepped mast. Zephyrzen Gear & Maintenance 2 04-17-2001 03:31 PM
