Sirocco 15 daysailer a good first "real" boat? - Page 2 - SailNet Community
post #11 of 16 Old 04-28-2017
Re: Sirocco 15 daysailer a good first "real" boat?
I was told the plug in the front just before the cabin was to fill with water for more weight. It would just fill the nose of the boat? I don't know though.
Shyfoxx can you send a pic of the heeling straps Mine do not attach to the back of the boat, just in the front before cabin.
This is my first sailboat and were cleaning her up and fixing up a pic of the rigging would be great as well.
I hope someone still replies to this site,
Thanks, Sharon.
kkreates is offline
post #12 of 16 Old 07-15-2017
Hi there,
Did you ever get any replies? I'm looking at buying one of these and have much the same questions. Thanks, Kieth
aprairieperson is offline
post #13 of 16 Old 08-21-2017
I just sold mine and I'm on vacation right now but will respond with a photo when I get home in 2 weeks...
enb54 is offline
post #14 of 16 Old 09-24-2017
Hello all... Have attached a few photos of my 1976 S-15 and will answer a few questions... The plug under the cuddy cabin as far as I know is just for emptying any water which may have got in there, not to add water for ballast. The hiking strap is attached at the cuddy cabin and at the stern, per attached photo. The main sheet rigging requires a double block to be attached at the fitting on the keel cover (between the swiveling cam cleat and the winch), then a stop knot is placed at that block with the sheet being run through that block and up to the boom block twice, then terminated at the swivel cam cleat. When I sold the boat this summer I made up a set of rigging instructions which were:
1) Unstrap mainmast and insert heel (base) of mainmast into mast step on cabin roof, ensuring that the bolt at the heel (base) of the mast is in the mast step slot and that the shrouds, spreaders and forestay are in correct position for attaching to hull chainplates and bow fitting
2) Attach shrouds to chainplates and raise mast, attaching forestay to bow fitting, ensuring halyards are not tangled
3) Make adjustments to shrouds if necessary, but they are a bit loose as I have them set up, maybe you’ll leave them the same at the beginning
4) Attach boom to mast via gooseneck fitting and wing nut
5) Disconnect trailer electrical connector
6) Launch boat into water ensuring all drain plugs are inserted and closed then secure boat to dock or beach
7) Insert mainsail foot into slot in boom and pull clew to end of boom, tension the clew now or later, insert cotter pin into tack near gooseneck and then insert luff of sail into mast slot and attach mainsail halyard to the head
8) Attach jib head to halyard and attach tack to deck bow fitting, then hank on jib to forestay
9) Attach rudder and ensure a safety line is attached to rudder frame and boat, you never ever want to lose your rudder
10) Attach mainsail control line (long ˝ inch line) to boom block, swiveling cam cleat, jib sheets via fairleads to port and starboard cam cleats
11) Partially lower centerboard and raise sails to start getting underway using cabin top jam cleats for jib and main halyards, then lower centerboard completely
Hope this information is of some help...
enb54 is offline
The Following User Says Thank You to enb54 For This Useful Post:
kkreates (09-26-2017)
post #15 of 16 Old 09-26-2017
Thanks Enb54. I appreciate the reply!
kkreates is offline
post #16 of 16 Old 09-26-2017
The mainsheet rigging requires a second block attached to the swing keel cover fitting, similar to figure 6 at the Ronstan mainsheet systems rigging guide. Have attached a view looking from the cockpit to the bow hiking straps. Happy Sailing!
enb54 is offline
Tags
daysailer , sirocco
"Good crew" looking for a Florida boat. Female, 48, professional lovehavana Crew Wanted/Available 14 10-07-2014 10:51 PM
"PLASTIKI" -- The real Deal or Just Another "Tin Can"? JohnRPollard General Discussion (sailing related) 10 03-10-2009 05:26 PM
Good resource - "I Boat NY Harbor" labatt Cruising & Liveaboard Forum 4 12-13-2008 09:33 AM
Suggestions for a "big" daysailer Quickstep192 Boat Review and Purchase Forum 20 08-26-2007 07:50 PM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
