Fuel leak in the steel keel tank - SailNet Community
post #1 of 4 Old 04-06-2018 Thread Starter
dennisonberwick's Avatar
When the boatyard recently moved SV Oceandrifter, the aft edge of the keel collided with obstacle, nicking the paint and causing a pinhole leak!
About 400 litres of diesel drained out (and was collected)
This was perhaps a happy accident - the boat is new to me and I was still working on repairing the 26 holes in the steel hull and deck. The boat, a Chevrier 36, is extremely well constructed with galvanized steel decks and stainless steel cockpit, as well as heavy winches and a 60 HP Perkins.
I'm making a series of videos showing the damage, investigation, repairs and what's been learned.
Video 1: vimeo.com/263457664
Video 2: vimeo.com/261448300
Creator of the Marine Diesel Basics books - the first VISUAL guides to marine diesel maintenance.
dennisonberwick is offline
post #2 of 4 Old 04-06-2018
S/V Dreamer - Marieholm26
regatta's Avatar
Re: Fuel leak in the steel keel tank
Video link for me doesn’t work!
Inviato dal mio iPhone utilizzando Tapatalk
regatta is offline
post #3 of 4 Old 04-06-2018
So your boat stores its diesel inside the keel, fascinating. You mentioned that you had fresh water leaking out first, so did your keel already have a hole elsewhere before?
That gate valve is in a hell of a spot. Having to unrivet the table and pull up 80 bolts before you can check it. Yikes. Hopefully there aren't any others elsewhere on the boat that need attention.
Sorry I don't really have any suggestions or helpful comments, I've been sailing most of my life but my knowledge about larger boats and their various systems is rather narrow.
interesting videos, i'll definitely be checking back to see how you're progressing. Good luck with the repairs!
slanter is offline
post #4 of 4 Old 04-06-2018 Thread Starter
Hi,
sorry you've had this problem - I know how frustrating it is when links aren't working. I just re-tested the links myself and both opened with the videos. May I ask you to please try again?
Dennison
Tags
accident , diesel leak , keel tank , marine diesel , videos
Cs-36t fuel tank leak soyuz Diesel 5 06-17-2014 07:59 AM
Ericson 27 fuel tank leak vindauga Ericson 3 07-07-2006 03:42 PM
fuel tank leak gart Gear & Maintenance 1 03-23-2004 12:04 PM
tiny leak in black iron fuel tank kathyspike Gear & Maintenance 2 11-17-2002 12:05 PM
Fuel Tank Leak silversea Gear & Maintenance 1 02-13-2002 04:05 AM
HTML code is Off
