Finally reinstalled the companionway hatch! - SailNet Community
 2Likes
post #1 of 11 Old 03-16-2019 Thread Starter
https://youtu.be/llpn_vq5RJU
BillMoran is online now
post #2 of 11 Old 03-16-2019
chef2sail's Avatar
Lightbulb Re: Finally reinstalled the companionway hatch!
Originally Posted by BillMoran View Post
Looking good����
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
The Following User Says Thank You to chef2sail For This Useful Post:
BillMoran (03-16-2019)
post #3 of 11 Old 03-16-2019
Glad the second coat of contact cement worked. Let us know how it holds up over time.
Scottelly likes this.
StillBreathin is offline
post #4 of 11 Old 03-16-2019 Thread Starter
That video was shot a few weeks ago, and I'm living on the boat so the hatch is opened and closed multiple times a day. So far, no problems. But the real test will be multiple years of use.
StillBreathin likes this.
post #5 of 11 Old 03-16-2019
I am about to take off my companionway hatch and I may have to do something similar. What kind of plastic rail is this? Source?
tx
MastUndSchotbruch is online now
post #6 of 11 Old 03-16-2019
UHMW (ultra high molecular weight polyethylene) is usually used for applications like this. Just make sure it's the real thing. I bought some that claimed to be UHMW but proved to be otherwise.
The Following User Says Thank You to StillBreathin For This Useful Post:
MastUndSchotbruch (03-17-2019)
post #7 of 11 Old 03-16-2019 Thread Starter
tx
In my case, there is a local marine store here in Fort Pierce that has a lot of salvage stuff. I dug through a shelf of recovered plastic sheets until I found this, then cut the strips to size.
The Following User Says Thank You to BillMoran For This Useful Post:
post #8 of 11 Old 03-17-2019
OK, tx. I hope it will hold up over time and you won't have to do it soon again in case the material is not sufficiently resistant to abrasion.
post #9 of 11 Old 03-17-2019
Thank you. I suppose this would be the real deal, right? https://www.mcmaster.com/uhmw-polyethylene-strips
The last point in their specs does give me a little pause (bolded by me):
Color: Off-White
Temperature Range: -20° to 180° F
Tensile Strength: 6,373 psi (Good)
Impact Strength: 16.8 ft.-lbs./in. (Excellent)
Hardness: Durometer 65D (Medium)
For Use Outdoors: No
post #10 of 11 Old 03-17-2019 Thread Starter
That probably means that the plastic is NOT UV stable. Meaning the sun will turn it brittle.
If it's shaded under a dodger, it _might_ last long enough to be worth using, but would be better to find an actual UV stable material.
I'm curious if there are materials other than plastic that might work better? I've seen boats with metal tracks but they also have metal on the opposite surface, so not sure if that would work with the way mine is designed?
Companionway hatch for E-27? captainbrad Ericson 5 09-25-2011 10:46 PM
Companionway Hatch Replacement danohayes Gear & Maintenance 9 10-23-2008 09:46 AM
WTB: Companionway hatch for Macgregor 25 goin_divin MacGregor 0 10-10-2007 08:08 PM
need to fab new companionway hatch nightowle Gear & Maintenance 46 04-13-2007 09:27 PM
Wood vs. Plexi - Companionway Hatch Boards lightyear22 Gear & Maintenance 7 03-16-2006 09:06 AM
HTML code is Off
