[Video] Will my 40 year old diesel start? - SailNet Community
 1Likes
  • 1 Post By VIEXILE
post #1 of 10 Old 04-04-2019 Thread Starter
https://youtu.be/2ZRAE3ZjiCA
BillMoran is online now
post #2 of 10 Old 04-04-2019
Re: [Video] Will my 40 year old diesel start?
Getting close Bill.
paulinnanaimo is online now
post #3 of 10 Old 04-04-2019 Thread Starter
Originally Posted by paulinnanaimo View Post
Getting close Bill.
Seems that way, doesn't it ...
That footage was shot about 2 weeks ago. Things haven't gone so well, since
post #4 of 10 Old 04-10-2019
So what's up with it? Usually a seal, a gasket, some tinkering will overcome a world of issues. Even though I've been sailing for 50 years, but not for the last 8 or 9 due to family issues, and been through half a dozen refits of various boats, I enjoy watching you while I do the same with my T37. You give this old **** confidence. Loved the masthead sheave replacement.
BillMoran likes this.
VIEXILE is offline
post #5 of 10 Old 04-10-2019
Once those new valves are underwater, they'll be under pressure, which may identify more weakness. I am a bit surprised you had any leaks. Your idea to plug from the outside can theoretically be done in the water too. I think I would only want to do so, with someone out there monitoring it. Not pound one in and then go back aboard and pull the valve. But it could avoid another trip to the lift.
Another thought would be to add a good pipe dope. I think that does better than teflon tape anyway. Also, the yellow teflon tape (max density) is much better. Some use both at the same time. Hopefully they held just fine.
You noted you ran the cooling water dry. Probably didn't matter, but I worry about impellers if run dry for any amount of time. I've had them look just fine, but fail shortly thereafter, at the worst possible time.
Jeanneau 54DS
Minnewaska is offline
post #6 of 10 Old 04-10-2019 Thread Starter
Glad you're enjoying the videos. What are you asking about, regarding the seal/gasket/etc?
post #7 of 10 Old 04-10-2019 Thread Starter
I didn't quite run it dry ... almost ... caught it just in time.
I think that's a good point about the impeller. It's the one that was on the boat when I bought it, so I don't actually know how old it is, despite the fact that it _looks_ Ok, it might be prudent to just put a new one on.
post #8 of 10 Old 04-11-2019
Originally Posted by BillMoran View Post
.....It's the one that was on the boat when I bought it, so I don't actually know how old it is, despite the fact that it _looks_ Ok, it might be prudent to just put a new one on.
Mandatory. Impellers only fail at the worst moments. BTDT. I replace mine annually. A visual inspection isn't going to catch much more than a serious failure that's too late anyway.
Jeanneau 54DS
The Following User Says Thank You to Minnewaska For This Useful Post:
BillMoran (04-11-2019)
post #9 of 10 Old 04-11-2019
Engine tinkering. My injector pump needs a seal and heat exchanger is going to get yanked and cleaned out. I haven't even stuck my head into the engine compartment for more than a couple minutes yet. Working on rudder, pintle and rebedding deck hardware. Bow to stern, deck to centerboard, float float, go forward go forward.
VIEXILE is offline
post #10 of 10 Old 04-11-2019 Thread Starter
I'm not having any issues with the engine at this time. She was a little lazy starting up, but I'm chalking that up to not having run for 18 months.
Just trying to do everything possible to ensure things continue to go well. Preventative maintenance and all that.
Replacing an 40 year old VP MD11C pguatney Diesel 2 07-31-2018 09:52 AM
A short film made with a 40 year old camera! Halcyon1 General Discussion (sailing related) 5 03-20-2016 02:28 PM
Buying a 30-40 year old boat - your opinions JulieMor General Discussion (sailing related) 103 10-26-2012 03:23 PM
Thinking of trading my 32-year old in for a 16-year old flyingwelshman General Discussion (sailing related) 13 12-02-2011 12:06 AM
Refinish 40 year old Gelcoat?! BlueVeins Gear & Maintenance 1 08-20-2008 09:46 PM
HTML code is Off
