[Video] Rebuilding the battery bank - SailNet Community
 11Likes
post #1 of 27 Old 06-17-2019 Thread Starter
https://youtu.be/1Ll4BlUZLSI
mbianka likes this.
BillMoran is offline
post #2 of 27 Old 06-17-2019
Re: [Video] Rebuilding the battery bank
You probably want the pos and neg connected to opposite ends of the bank
SanderO likes this.
RegisteredUser is online now
post #3 of 27 Old 06-17-2019 Thread Starter
They are.
post #4 of 27 Old 06-17-2019
colemj's Avatar
Different capacity batteries in parallel cannot overcharge, undercharge, or over-discharge just because they are different capacities. They will be at the same states of charge, with the same voltages at all times.
Mark
MastUndSchotbruch likes this.
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #5 of 27 Old 06-17-2019 Thread Starter
Mark
If that's the case, then why is it considered important to have matched batteries?
post #6 of 27 Old 06-17-2019
colemj's Avatar
It is important to match batteries in age and internal resistance to allow them to operate and age the same. It is important to match them in type to allow them to charge with the same optimum parameters. They need to be close in capacity if they are to be connected serially, but it isn't critical for parallel. In practice when building a bank though, it is generally a good idea to match them in capacity when in parallel too. But this isn't because of charging issues - it is more aging related, where over time different capacity batteries will age differently and the bank as a whole will likely have a shorter life than otherwise.
Any electrochemical cells of any sizes put in parallel will rise and fall at the same voltages at the same time. There can be no overcharging or undercharging unless the charge source is set this way for the particular chemistry - in which case, all of the cells will be overcharged or undercharged.
It is how combiners charge multiple batteries from a single source, and is the same as having a 1-2-both switch set to both.
Mark
- Current boat
- Previous boat
colemj is offline
post #7 of 27 Old 06-17-2019
colemj's Avatar
As an extreme example of no harm from paralleling batteries, we have a large lithium bank paralleled continually with two small flooded lead acid automotive start batteries and all works fine. The FLA's are not receiving an optimum charge profile of course because they are forced to the lithium charge profile, so they may live a shorter life than they otherwise would, but they are not being damaged from being paralleled into the larger bank.
Mark
- Current boat
- Previous boat
colemj is offline
post #8 of 27 Old 06-18-2019
Super Moderator
Maine Sail's Avatar
Mark
Mark is spot on with this point..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #9 of 27 Old 06-18-2019
Super Moderator
Maine Sail's Avatar
Originally Posted by BillMoran View Post
Wire tie that neg cable out of the way of the positive terminal of the battery (inside the batery box) as that is a short that would occur before a fuse and could prove quite destructive if it did...
______
post #10 of 27 Old 06-18-2019
By matched batteries are they referring to matched size or AH or matched age or condition?
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is offline
HTML code is Off
