Heave To - Page 4 - SailNet Community
 76Likes
post #31 of 85 Old 07-23-2019
Administrator
Jeff_H's Avatar
Re: Heave To
Originally Posted by caberg View Post
That's heaving-to? Looks kind of like a poorly trimmed/luffing main. I always thought a backed jib was essential to heaving-to.
Originally Posted by Arcb View Post
Thanks for bringing up the misconception that you need a jib/sloop rig to heave to.
As far as I know, the idea is to create an equlibrium between driving forces (sails) and control surfaces (rudders, skegs, boards etc.), resulting in a boat that is a) self steering/self tending and b) presents something other than the most vulnerable part of the boat to breaking seas.
In my video the boat is self steering, self tending, presenting the starboard bow to the breaking waves, not making headway, not making stern way, just gently sliding to leeward. How is that not hove to?
My other boat is also cat rigged (Bay Hen) and heaves to in much the same way. Position of boards is critical in establishing equilibrium on some boats (both of mine).
People were heaving to long before sloop rigged keel boats came along by creating equilibrium by whatever means were at their disposal.
That video actually does appear to show the kayak Hove-to but you need to look at through the lens of being a cat ketch with unconventional sails, because that is how it is functioning.
The real sail in the video is the obvious sail. Slacked so it produces minimal drive, combined with the windage of the mast and boom, in its position near the bow is mostly creating a side force trying to pull the bow of the boat to leeward in much the same way as a a back-winded jib pulls the bow to leeward. The other sail is less obvious, and it is badly stalled. That sail is the paddlers body above the coaming of the kayak, which tries to pull the stern of the boat to leeward. The windage of boat, paddler, mast, and sails slows the forward motion in much the same way that the backwinded jib reduces forereaching. The thin long length of the kayak in the water produces is a very low aspect keel that resists these two forces (sail and paddler) to leeward, and so slows leeway. The skeg (and mainsheet) allows the center of lateral resistance to be fine tuned to result in the balance necessary to result in an essentially sideward motion to leeward.
Back to the show in progress,
Sailormon6, Minnesail and Arcb like this.
Jeff_H is online now
post #32 of 85 Old 07-23-2019
outbound's Avatar
Re: Heave To
Accordingly to the met
Storm
Winds of force 10 (48-55 knots) or gusts reaching 61-68 knots
Violent storm
Winds of force 11 (56-63 knots) or gusts of 69 knots or more
Please do not heave to in these conditions. History shows there are ways to deal with these conditions more likely to result in survival.
Please read the myriad sources concerning this or even success rate of hove to boats in the fast net in the hopes you change your storm tactics.
s/v Hippocampus
Outbound 46
outbound is online now
post #33 of 85 Old 07-24-2019
Old soul
MikeOReilly's Avatar
Re: Heave To
Your comment got me searching the old Fastnet findings once again. My recollection was that the principle findings had to do with problematic design issues driving by the IOR, and of course the demand to go fast. The report(s) found that the push to beamy flatter boats, accompanied with weak steering systems, were the principle problems.
The report notes that the worst tactic appears to be passive, and by that they did not mean heaving-to, but lying a-hull with bare poles. Indeed, of the boats that hove-to, only one experienced serious damage.
Full report: http://www.blur.se/images/fastnet-race-inquiry.pdf
Summary: https://uk.boats.com/on-the-water/le...-fastnet-race/
Why go fast, when you can go slow.
BLOG:
MikeOReilly is online now
post #34 of 85 Old 07-24-2019
outbound's Avatar
Re: Heave To
My bad youíre right but if you research this some youíll see heaving to to is a very viable tactic for gales. However once storm force, violent storm or hurricane force is seen boats heaved to donít fair well. Rather in many modern boats youíll fair better fore reaching under heavily reef jib or storm jib alone which allows an easier transition to jsd if winds increase from gale force to storm.
So although I would heave to on prior boats at present have dropped the technique from heavy weather protocol. I have learned to have less confidence in weather forecasting so know although they maybe be in predictions for general conditions for an area they maybe incorrect for what we are experiencing in our hyperlocal area.
Current protocol is reef down to third reef on main with reefed solent. At that point hang and rig the storm jib but not raise it. Do this earlier if prediction is for further deterioration. Then fore reach on storm jib. AP or windvane goes off and hand steer at this point. Once storm force is reached out goes jsd and sails down.
Similarly halved dropped bare poles alone as a technique. Or use of a sea anchor from the bow.
Please look at attainable adventure or any blog of repetitive passage makers and be made aware that for storms many people have moved passed the Lin and Larry thinking of the past.
Lastly people have added the use of the jsd as a storm tactic for vessels passage making power vessels.
Minnesail likes this.
s/v Hippocampus
Outbound 46
post #35 of 85 Old 07-24-2019
Re: Heave To
Iím surprised that riding a JSD off the bow isnít the recommended approach. I know (first hand) that parachute sea anchors can pull out of waves faces. Even with a storm sail or postage stamp reefed jib, running downwind (or any point of sail), dragging a drogue, the boat is still subject to a violent shift in wind direction, in a storm. Thatís not set it and forget it. Bow into the waves seems more natural, better for the rudder, requires absolutely no attention (other than chafe) and waves dint shift as quickly as wind.
Jeanneau 54DS
Minnewaska is offline
post #36 of 85 Old 07-24-2019
Old soul
Re: Heave To
Iíve never experience more than a gale while out to sea, so will not pretend to have any great wisdom on this. Iíve read and studied much of what has been written on the topic, any my conclusion is that the best tactic depends on sea state, boat, and crew.
IOW, there is no one right answer for everyone (as usual).
From what Iíve read, I think you are bang-on with regard to many (most) modern boats. Those that follow the trend of flatter and beamer, with longer thinner appendages (keel/rudder) seem harder to effectively heave-to, but also seem to do much better running with the seas. Streaming some sort of drogue helps control direction and speed.
Boats like mine (full heavy keel, narrower body, less efficient rudder) donít run well down steep waves, but we do hove-to very well. Iíve seen the slick in action, and it does seem to protect the boat from the worst of the oncoming seas, but Iíve never tested this in anything beyond gale (and hope I never have to).
Guess the only point I want to make is, it really depends on boat and crew, and of course sea state, as to what the best approach might be. Itís good to emphasize that the traditional technique of heaving-to may not be the best option for most newer-designed boats, but for the fleet of good-old-boats that still ply the waters, it remains an effective option.
eherlihy, Minnesail and Arcb like this.
BLOG:
post #37 of 85 Old 07-24-2019 Thread Starter
Moderator
Arcb's Avatar
Re: Heave To
I can't really think of a lot of options other than heaving to to take a break in heavy weather on your typical sub 30 ft boat (I know we are badly under represented on this site, but there really are a lot of us).
Bare poles? Not on my boat thanks. Drogue? I don't know very many boats that have them on board. Under 30 ft, I can think of exactly zero that I know of.
I do actually have a sea anchor. Its been sitting in a bin in a basement collecting dust for years.
Not all boats taken out or disabled by heavy weather are on offshore passages, I have no idea where to look for the statistics, but I suspect a decent percentage are small boats reasonably close to shore. I think for those boats heaving to is a viable tactic.
I know of one single handed sailor this year that hove to in a Sea Pearl 21 (unballasted 21 ft cat ketch) because he was too worn out (and I beleive sea sick) to sail the boat any more.
Its not a tactic I would entirely discount for heavy weather. Some boats may have better options, but a lot don't.
Even the Fastnet race is within 100 miles of shore in either direction and there are numerous other examples of races gone badly relatively close to shore.
Arcb is offline
post #38 of 85 Old 07-24-2019
Re: Heave To
What makes you say 'better for the rudder?" Isn't there a lot of force on the rudder when the boat goes backwards?
Other than that, everything else makes sense.
MastUndSchotbruch is online now
post #39 of 85 Old 07-24-2019
outbound's Avatar
Re: Heave To
I have ridden out weather with warps and a pocket handkerchief of a jib. This works up to~10í seas and gives directional stability. However beyond that the boat starts to surf too fast. The water can run faster or as fast as the boat so thereís no input as you steer at times. . It is not the best solution.
Parachute anchors off the stern or off the bow run risks. Any collapse of the chute, chafe, or breakage of lines or the webbing of the chute can result in total failure. JSD or like devices are TOTALLY passive. All sail is down, helm is lashed, and failure of even multiple cones does not result in catastrophic failure unlike with sea anchors. Loading of the boat or deck fixtures is significant but much less than with sea anchors. Sea anchors are usually cut away as there is no feasible way for a short handed crew to retrieve them. JSDs are retrieved.
Multiple single handed sailors have routinely and repetitively used jsd. You do have to wait until winds are in the thirties but they can be retrieved. Set a block on a strong point at the bow and run a line two and a half times the length of the boat through it. Attach this line to the jsd with a truckers hitch. Pull in one boat length. Undo line and reattach to jsd. Do it again. Repeat until jsd is recovered. The reason not to use dyneema for jsd is it makes retrieving more difficult.
Realize we are talking about storms not gales. In 35 years Iíve been in one storm in a coastal setting. The rest have been brief t-storms, squalls and rare gales. Other than the gales when by myself or with non sailors have simply dropped all sail and turned on the engine. Given the brevity of these events and proximity to land believe this is often safer. I can head a fraction off the wind and the boat rides nice. I can still avoid obstacles and grounding. Thinking about this itís actually very rare a recreational sailboat will be in a storm. Suspect even less likely in a coastal setting. Gales are more frequent. However, even if looking at a prolonged gale if you arenít certain it wonít evolve into a storm the jsd maybe the safer option especially if short handed as it is truly passive.
For our 46k boat the jsd is heavy. But even as a fat old man I can carry it up from below and deploy it. In original plans for the boat we made modifications. The aft cleats were moved further aft, backing plates were glassed in, under the cleats smooth ss plates were run to the extreme aft of the boat. Thereís no opportunity for chafe nor loading to cause failure. Iím not suggesting jsd for all the average small boat recreational sailors. However regardless of size or coastal v offshore use if thereís a reasonable concern about being in weather itís another bullet in the gun. We were chatting with a guy on a ancient BCC 28í in St. Vincent. He had much more experience than I in its use. He had even taken to using it for a sleep break when in unsettled weather although it had yet to reach him. Iíve yet to use mine in a storm and hopefully never will.
Should mention when fore reaching with a jib the jib is reefed back to the point the steerage is maintained. You hand steer or set the AP(depending on sophistication of the device) so broaching is avoided. You arenít going fast at all. You want to continue the rise as the wave train goes by. You do not want prolonged surfing. Safer than bare poles.
s/v Hippocampus
Outbound 46
post #40 of 85 Old 07-24-2019
Minnesail's Avatar
Re: Heave To
Bwaaa haaaa haaa haa! LLOL
In addition to being badly stalled, in my case the sail is a bit too full and resists all attempts to flatten it.
Jeff_H, eherlihy and Arcb like this.
Catalina 22
on a starboard tack
Minnesail is offline
HTML code is Off
