What Kind of a Keel do you Have - SailNet Community
 75Likes
post #1 of 99 Old 07-26-2019 Thread Starter
Moderator
Arcb's Avatar
Fin keel, full keel, long keel, stub keel with centre board, bilge keel, swing keel, lifting keel,bilge keels, canting keel, water ballast, centreboard, daggerboard, chine logs, bilge boards, foils, Multi hull with any of the above. And whatever I missed.
Why do you like what you have.
In this vid I am using "Chines" for lateral resistance. My Sharpie can do the same. The benefit is very shallow draft, the negative is you don't really get much in the way of lift, so you can't point as high as some boats.
Arcb is offline
post #2 of 99 Old 07-27-2019
overbored's Avatar
Re: What Kind of a Keel do you Have
bulb keel or as we call it kelp catcher keel most fun dinghy I have sailed with only one hull
Arcb likes this.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #3 of 99 Old 07-27-2019
Swept, shoal depth, fin keel, with a modified bulb. Perhaps one can make it out in my signature below.
Best all around option for us. Reduces draft to 6.5ft on a 54ft LOA, expanding anchorage or harbor choices. Improves maneuverability (along with the spade rudder) in tight quarters. Does a reasonable job holding off leeway, but Iím sure the standard 9ft keel would have performed better.
Arcb likes this.
Jeanneau 54DS
Minnewaska is offline
post #4 of 99 Old 07-27-2019 Thread Starter
Moderator
Arcb's Avatar
Note to the mods, I wasn't really sure what category to put this vid in. It isn't really racing and isn't really cruising. It was just going out and having fun messing about with a sailing machine.
Arcb is offline
post #5 of 99 Old 07-27-2019
Old soul
MikeOReilly's Avatar
Too bad this wasnít an actual poll. Would be interesting to see the raw data.
Mine is a full keel (I mean FULL!). Moderately-deep, encapsulated.
Like: Excellent at tracking and maintaining a line. Very easy on the helm. Strong; canít easily be damaged. Protects rudder/prop. Doesnít snag any wayward fishing gear. Sits well on her keel so easy haul out or dry out.
Dislike (even though you didnít ask): Not very maneuverable, so docking is challenging. Not very efficient up-wind. Lots of wetted surface so takes a bit more time to get moving. Also costs a lot more in bottom paint.
Arcb likes this.
Why go fast, when you can go slow.
BLOG:
MikeOReilly is online now
post #6 of 99 Old 07-27-2019
outbound's Avatar
Leeboards on the CF dinghy.
Bulbed fin on the Outbound.
Keels should be appropriate to the use of the boat. Pure form follows function. Keels need to be thought of in terms of the totality of the boat-canoe body, other appendages, house, sailplan. If the boat was drawn by a skilled NA it has the “right” keel for that boat. Likes or dislikes should refer to the boat in most cases as what keel it has is the natural evolution from the design.
Believe there is little or no correlation between keel type and tracking. There is between wetted surface however and type.
There isn’t between type and risk of damage with some outliers such as daggerboards on multis v fixed keels.
With IP going under other than heritage yachts pure full keels will gradually disappear. They made sense when building in wood but not for performance.
When I give up long range cruising I want a Lyle Hess 32. Totally illogical but beautiful. Totally contrary to current thinking but perfect in design for that style of boat.
s/v Hippocampus
Outbound 46
outbound is online now
post #7 of 99 Old 07-27-2019
Telesail's Avatar
Welded fin on Aluminium hull with a lead bulb (but no projection of the bulb in front of the fin to allow snagged lines etc to be freed easily). Allows us to limit draft to 8í 3Ē but maintain some semblance of upwind capability. However, she is really designed to go downwind.
Minnesail likes this.
Telesail is online now
post #8 of 99 Old 07-27-2019
My beach built 17' skiff used a single flipp'er over lee board. Angled to foil to windward. Very effective , if a bit of learning curve in timing/tack. Thane had a 40'slab of wood,6 feet down there. Steady as she goes .
Capt Len is online now
post #9 of 99 Old 07-27-2019
SanderO's Avatar
Like this
baywater likes this.
pay attention... someone's life depends on it
SanderO is online now
post #10 of 99 Old 07-27-2019
Old soul
Well, if weíre showing off our bottoms Ö
Sal Paradise likes this.
BLOG:
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
dh27
HTML code is Off
