Rapid Disintegration of Saildrive Leg - SailNet Community
 2Likes
post #1 of 21 Old 02-08-2020 Thread Starter
I don't discuss my member
Fstbttms's Avatar
It didn't look like this three months ago:
https://youtu.be/88ax4YKe9H0
capta and overthehorizon like this.
Fstbttms is offline
post #2 of 21 Old 02-08-2020
Re: Rapid Disintegration of Saildrive Leg
Looks expen$ive
RegisteredUser is online now
post #3 of 21 Old 02-08-2020
overbored's Avatar
What do you think is going on. Anodes are still intact. if the starboard anode is 3 months old then it is not working, looks brand new. stray current or ground problem in the marina could be the cause on the left but if so why is the anode not eaten up first. does the boat have Galvanic idolators?
"GOLD RUSH" PRINDLE 16
overbored is online now
post #4 of 21 Old 02-12-2020 Thread Starter
Fstbttms's Avatar
That anode was replaced at the time the video was made.
Likely a 12-volt issue aboard the boat in question. Definitely electrolytic (stray current) corrosion.
...does the boat have Galvanic idolators?
No idea.
Fstbttms is offline
post #5 of 21 Old 02-12-2020
Super Moderator
Maine Sail's Avatar
Bingo! A galvanic isolator does not protect from stray DC, especially when it originates on-board....
______
-Maine Sail / CS-36T
Maine Sail is offline
post #6 of 21 Old 02-12-2020
colemj's Avatar
Volvo or Yanmar? L380's came with both choices. Volvo saildrive is electrically isolated from the engine, while Yanmar is not. An electrical issue on the engine should not effect the Volvo drive, but would have a straight path to water with a Yanmar.
The one weakness with Volvo's isolation approach is that the cooling water is often drawn through the leg, so this could potentially be an electrical path. Changing to a separate intake thruhull prevents this, as well as other issues.
Mark
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #7 of 21 Old 02-14-2020 Thread Starter
Fstbttms's Avatar
Originally Posted by colemj View Post
Volvo or Yanmar?
Yanmar.
Fstbttms is offline
post #8 of 21 Old 02-14-2020
Looks even worse than the Volvo sail drive leg I saw on a sloop, on the hard, back in the 80's. Looked like crumbling cheese, sort of.
Did not know the details, but it was in a salt water environment.
It was a sickening sight.
1988 Olson 34, by Ericson Yachts.
Sail # 28400
Betamarine 25 (new 2018)
RCYC, Portland, Oregon
olson34 is online now
post #9 of 21 Old 02-14-2020
overbored's Avatar
true but it does protect your anode from being eating up by other boats in the marina and then your saildrive from then being the least noble metal and eaten up by the other boats in the marina. aluminum sail drive makes a great anode for all the other boats in a marina
post #10 of 21 Old 02-14-2020
colemj's Avatar
Only through DC impressed on the AC circuit. Won't help for galvanic action from a rusting hulk with DC issues next to your boat.
But this is almost certainly a problem on the boat itself. My guess is a wire chafe on the engine harness or alternator/starter wires.
Mark
- Current boat
- Previous boat
colemj is offline
HTML code is Off
