Spirit 23 potential purchase - SailNet Community
post #1 of 43 Old 09-26-2017 Thread Starter
Hi there, mateys! I'm fairly new to Sailnet.
I'm considering buying the local yacht club's Spirit 23 sailboat. It's in pretty good shape but for two things, which I want some info on... mostly, how difficult these repairs will be.
1. Cockpit sole is soft... no doubt about it. What's it like to do a proper repair of such?
2. The cable which hoists/lowers the centerboard is broken. I've seen a fix elsewhere on Sailnet... but still seems like a difficult job.
I don't know what the club is asking yet for the boat (they have a "board" meeting coming up Oct 4 or so to discuss whether they want to sell it or not.
The rest of the boat and sails check out ok. I've sailed the boat twice and like its feel.
No trailer... I think I can find one fairly close to me (I live on the Oregon coast... lots of boats and trailers).
Price-wise I'm thinking $800-1000.
Ocean bay sailing and an occasional foray out of the bay into the Pacific ocean (when conditions allow for such) are what I do. I currently have a Bayliner Buccaneer 200. It's a good solid boat and I like it. But I have an urge to get out in the ocean a bit more frequently and think the Spirit 23 might be a good boat for that.
Any comments/help/suggestions would be welcome.
Thanks.
Hal Nash
Waldport OR
hnash53 is offline
post #2 of 43 Old 09-26-2017
Re: Spirit 23 potential purchase
The cockpits sole is probably uncored and fatigued. If so, you can stiffen it with a beam bonded from below.
Hudsonian is offline
post #3 of 43 Old 09-27-2017 Thread Starter
By "uncored," are you saying that the cockpit floor is construction is NOT the fiberglass/plywood/fiberglass sandwich? That there's no wood core there?
Thanks for the help.
hnash53 is offline
post #4 of 43 Old 09-27-2017
I think he means the plywood is rotted away.
Deina is offline
post #5 of 43 Old 09-27-2017
Freedom isn't free
Dock
Plywood is definitely gone... no way its solid glass, and if it was it wouldn't fatigue.
The keel cable is a difficult repair from the standpoint you must drop a 600lb keel out and rethread it. Usually (as crazy as it seems) people raise the boat away from the keel do their repairs, then lower the boat back to the keel. Unless you have a trailer that has a removeable floor, one with adjustable supports allows you to raise the boat away from the keel.
Spirit 23 is a great little move up cruiser/racer from the Buccaneer. Price seems reasonable if it includes a working trailer.
Freedom, a 1983 C&C 32 sailing Smith Mountain Lake, VA
SHNOOL is online now
post #6 of 43 Old 09-27-2017
blobaugh's Avatar
The cable being replaced is for a swing out centerboard, not an entire keel. The centerboard on these boats is light. It is mostly for additional stability upwind.
I build a new centerboard and ran a new cable. It is not difficult at all. The other post on this site shows how to make alterations so the cable is at a better angle and less likely to break. The way the cable runs from the factory puts stress on them and causes them to snap.
Now that said, unless you are trying for high performance leaving the centerboard down all the time is not a problem. After rebuilding mine a shop bunged something up and it would not move anymore. I have kept it down for years with no problem.
If you are wanting to trailer it the centerboard should fold right up when you slide it onto the trailer.
I actually sailed my boat without a centerboard for the first year I owned it so they are not strictly necessary on this boat due to the stub of keel down there already. You will not be able to point as high without it but you will still be able to sail.
blobaugh is offline
post #7 of 43 Old 09-27-2017 Thread Starter
Thanks for the comments. The second post also says something about stiffening the cockpit sole with a "beam bonded from below."
What is meant by that?
Yes, the centerboard is not all that heavy in these Spirit 23s. Good the hear that it will sail ok even without the CD extended. But when sailing this boat myself, it pointed very well in light air that day, so the CB must add some performance.
hnash53 is offline
post #8 of 43 Old 09-27-2017
blobaugh's Avatar
Oh yes, the centerboard helps pointing tremendously. It will also stop/prevent a lot of side slippage when pointing high.
For light wind sailing I had a lightweight 160 drifter sail. It was glorious.
For some performance tweaks check out the racing thread.
blobaugh is offline
post #9 of 43 Old 09-27-2017
Barquito
Barquito's Avatar
I would sort out if there is actually a trailer available to buy. In some places it is really difficult to find a trailer that fits for a reasonable price.
This is what the fiberglass covered beam under the cockpit floor may look like.
Valiant 32
Barquito is online now
post #10 of 43 Old 09-27-2017
blobaugh's Avatar
If a trailer is desired. Mine came with a trailer in 2010 and I have used the trailer only once, and that because I did not have the time to sail to the new location.
I guess that means I have a trailer if you need one...
blobaugh is offline
Potential Pearson 303 purchase AlexD Introduce Yourself 4 11-02-2019 10:13 PM
Potential Moorings Catamaran purchase DavidPietrowski General Discussion (sailing related) 0 08-03-2015 06:16 PM
Horizon 26 - Potential Purchase karluk Boat Review and Purchase Forum 2 09-08-2010 10:29 PM
Consult Needed on Potential Boat Purchase danielgoldberg Boat Review and Purchase Forum 76 02-26-2009 11:29 PM
Potential first boat purchase sonofason Boat Review and Purchase Forum 45 01-19-2007 03:55 PM
HTML code is Off
