Hull liner coming off/loose... remove and paint? - Page 2 - SailNet Community
post #11 of 12 Old 04-14-2018
Re: Hull liner coming off/loose... remove and paint?
Just finished putting together a video that includes some footage of me cleaning up and reworking my companionway hatch: https://youtu.be/I_yO3hbOSv0
BillMoran is offline
post #12 of 12 Old 04-15-2018
If you look here you can see where I lined the sides with inexpensive outdoor carpet, no foam. https://www.sailnet.com/forums/3436705-post37.html Really quiets and warms up the inside. Have not had condensation problems but without the foam the carpet breathes and should dry pretty easily. I have also fixed "most" of the leaks except a tiny bit around the chainplates that gets down occasionally. Which is why I replaced those small bulkheads with starboard!
tschmidty is offline
Has anybody used cork for the inside hull liner JimF54 Gear & Maintenance 4 10-25-2016 12:51 AM
Beneteau hull liner replacement. gedaggett Gear & Maintenance 26 04-06-2016 09:12 PM
Rudder seal coming loose postwarcomet27 Gear & Maintenance 7 06-16-2013 11:02 PM
Do liner boats get mold in between the liner and the hull? Jgbrown General Discussion (sailing related) 20 11-13-2012 06:04 PM
hull reinforcement with liner xact Gear & Maintenance 19 02-04-2010 07:40 PM
HTML code is Off
