Material used in Spirit/NA 23 Centerboard - SailNet Community
post #1 of 7 Old 04-27-2018 Thread Starter
Material used in STOCK Spirit/NA 23 Centerboard
What is the STOCK centerboard in NA23/Spirit23 made of?
Are they all fiberglass? Fiberglass and plywood?
Thanks.
Hal
Waldport OR
hnash53 is offline
post #2 of 7 Old 06-11-2018
blobaugh's Avatar
Re: Material used in Spirit/NA 23 Centerboard
Hey Hal, I did not see this thread, sorry about that.
When I first got my Spirit 23 there was only a stub of the board remaining! I believe it was originally foam filled fiberglass with weight on the bottom.
Here is a photo of the stub
In my first haul out post I showed the new board that we built.
https://ben.lobaugh.net/ship-log/zdd...t-and-painting
It was made from two inch pieces of plywood epoxied together and glassed. It has worked out just fine. The only issue I have had was not being able to get the centerboard back up after some growth was on it.
Here is a photo
blobaugh is offline
post #3 of 7 Old 06-11-2018
blobaugh's Avatar
Also, here is an older post where there is chatter about a centerboard rebuild
https://www.sailnet.com/forums/north-...ard-specs.html
blobaugh is offline
post #4 of 7 Old 06-16-2018 Thread Starter
Ben... thanks for the reply. I wanted to know because I drilled a hole through the tip in the hopes of having a "redneck centerboard lift" but it didn't work out. I ended up putting some Splash Zone underwater epoxy in the hole to plug it up. Glad to hear that the original CBs were fiberglass and foam core.
But even with a foam core, wouldn't the board need some more weight added to it so that it would stay down? How did you get your plywood board to stay down?
hnash53 is offline
post #5 of 7 Old 06-18-2018
blobaugh's Avatar
Yes, you would need weight on the low side of the board for it to swing out and stay down if you filled it with foam. In the other thread they talked about weights for the boards.
blobaugh is offline
post #6 of 7 Old 06-18-2018
It's hard to imagine that the stock center board didn't include some lead but if your board doesn't have any and you want to add some, McMaster Carr and other online sources sell appropriate lead disks. For example, a 4.5" diameter, 1/2" thick disk weighs 3.25 lbs.
Hudsonian is offline
post #7 of 7 Old 06-18-2018
I was able to pick up some lead scrap from a metal recycler so you could look into that.
tschmidty is offline
Spirit 6.5 silverado North American Yachts 13 11-05-2019 07:51 PM
Spirit 23 originalgavman North American Yachts 3 03-03-2017 01:00 PM
Companion Way Sliding Hatch Mold For Spirit 21' & Hatch For Spirit 23' For Sale tomsayres Gear & Maintenance 0 10-11-2015 09:51 PM
Centerboard position - keel/centerboard Tartan 37 upwind cspear Racing 14 07-02-2012 01:31 PM
HTML code is Off
