New owner of a Parker Dawson 26 Ketch - Page 14 - SailNet Community
 12Likes
Re: New owner of a Parker Dawson 26 Ketch
Thanks for offering your trailer. That was very thoughtful! I'll keep that in mind as an option should I find it difficult to get one for the boat. My challenge is timing when the keel work will complete. Maine generally operates on it's own clock :-) Patience is a virtue there. The Maine coast is an amazing place to sail. Just keep an eye out for lobster pots and ledge. I'm in a little harbor north of Bar Harbor. Mostly lobster boats.
Wmullikin is offline
Hi Alan,
Wonder if you can help. I'm talking to a trailer supplier and they have 2 questions. (I'd do this except my boat is 600 miles north!)
1. When the keel is retracted, does it go all the way up inside the hull or does some stick out? If it sticks out about how many inches?
2. 30 inches in from from the stern, how far down does the prop or shaft extend down from the hull?
Thanks,
Walt
post #133 of 133 Unread 5 Days Ago Thread Starter
Yes, the keel sticks down a good bit. I will be at my boat probably next weekend and can give you a good measurement then.
Likewise on the prop and strut.
One thing to keep in mind is that trailers on these guys don't tend to be terribly long since the more stuff you have coming past the area that needs supporting the more ways you have to end up with your trailer getting into trouble on a short ramp. One of the as designed advantages of the Dawson is the ability to launch and recover off of fairly “normal” ramps which can be handy.
If you look at this picture here you get something of an idea what I am talking about although in this exact pic, the boat is actually about 6 inches further back than usual since we just had the boat out for a bit to pull the engine and do some service work. Either way, keep in mind that most of the weight on the Dawson is pretty well centered
Aswayze is offline
Presto 36 Munroe/Parker design, Seaworthy?? benesailor General Discussion (sailing related) 12 11-08-2013 10:00 PM
Parker R12P Fuel/Water Separator bobmorning Gear & Maintenance 1 08-25-2010 09:46 PM
A New Fuel Polishing Option - Parker FPM arisatx Gear & Maintenance 2 08-25-2009 12:29 PM
Can anyone help a New Boat Owner ona custom Ketch? sailinginruskin Boat Review and Purchase Forum 11 08-09-2009 02:15 PM
new ketch owner stykman Learning to Sail 1 11-15-2004 01:16 PM
