Midships 25 Hull number 65 shall rise again - Page 5 - SailNet Community
 25Likes
post #41 of 51 Old 04-15-2018
Re: Midships 25 Hull number 65 shall rise again
Its warm and sunny outside. Perfect weather for sailing.
Somehow, however, my version of sailing seems to involve lots of wrenches and tools.
For those of you keeping up with the craziness of SV Sunflower. The current project is the "new" yanmar YSB8.
The previous powerplant, the Baldwin Saildrive is going to CW3Shannon, and is somewhere in the postal system.
Here is the new power plant, sitting the shop.
I bought a pair of these yanmar engines, or so I thought.
Turns out we have 1.7333 engines. I'm short an Injection pump and and the injector, but have everything else in spades. So, I now have a plentiful supply of working spare parts.
Going to fetch it was a 8hr drive one way, so I took the fuel efficient car.... We managed to cram both engines and all the extra parts into my Hyundai Elantra. Pictures exist but don't do the task any justice.
Once everything was home it was time to alternatively ignore everything, and then work feverishly, before ignoring it again. (besides it was cold outside)
Step 1 through 73 is strip it down and repaint, refurbish, and inspect everything.
Step 74 is create yanmar windchimes in the backyard.
Which gets us caught up from the last couple of months to this weekend.
This weekend has been a constant task of prep, hang, paint, and repeat. But the growing pile of new looking parts is pretty rewarding work.
Towguy and slanter like this.
stagg is offline
post #42 of 51 Old 04-15-2018
The only real battle I've had with this engine is removing the cylinder.
It is pretty well glued in place, by rust, salt, and calcium buildup.
Here it is bubbling away in a bath of acid.
20180414_205631
Hopefully this will convince the engine to give up on this old cylinder, so I can replace it.
While the block is getting the acid treatment, its time to try reviving the piston.
stagg is offline
post #43 of 51 Old 04-15-2018 Thread Starter
Boil boil toil and trouble!
Aswayze is online now
post #44 of 51 Old 04-16-2018
midwesterner's Avatar
How cool. Thanks for sharing. I did this kind of project 35 years ago with a couple of VW beetle engines. I look forward to following your adventure.
midwesterner is offline
post #45 of 51 Old 04-16-2018
I'm cleaning up the engine block and transmission, and a couple of ah-ha moment.
There are two dipstick lengths. Same plastic threaded piece at the top.
Which one goes where?
Well wonder no more. Aswayze measured his for me, and the results are in.
The long version makes sense in the transmission. I'm absolutely certain that I don't need my starter in an oil bath, and currently the short dipstick was juuust barely touching the tranmission oil.
The short stick goes in the engine block, which holds a fairly large amount of oil.
I'm inclined to think the previous owner mixed them up.... Might be why the cylinder and piston are all torn up too.
stagg is offline
post #46 of 51 Old 04-30-2018
More re-engineing (spell checker doesn't believe that is a word)
Start with prep work. Might as well TRY to keep the dust storm out of the rest of the boat.
Find the 60 grit flap sanding disk.
And fill the entire boat with fiberglass dust by grinding a giant hole in the bottom!
The bottom of the boat is 3/4 to 1 inch of solid glass. I needed a 6:1 sloping angle on the side walls for a strong patch (just ask Don Casey for the details)
Using epoxy and biaxial weave fiberglass fill in the hole, in about 3 stages to keep the epoxy curing at a lower temp.
Here is the finished product, that will keep the seas out, and the boat on top of the water.
The next hurdle will be measuring and building the engine mounts.
This is the engine mount from SV Eastwind, and the rough model for the mounts that I will be making.
slanter likes this.
stagg is offline
post #47 of 51 Old 05-06-2018 Thread Starter
Since Stagg has been remiss in his updates I will chime in.
He was having a tough time getting the cylinder out of this engine despite the best efforts of my Mark2 Mod0 cylinder knocker outer tool I mailed down to him conveniently stuffed into one 40 pound flat rate box. Having had enough of my helpful heckling from 1000 miles away Stagg decided to load up his Hyundai and drive up to Kansas City and tell me to put up or shut up.
Turns out that yes, the cylinder was very very very stuck.
No matter...
Step 1: Shatter the cylinder. This will allow us to fight each stuck half separately. The cylinders are cast iron and believe it or not, they shatter without too much effort.
Next take a hack saw and carefully cut MOST of the way through the cylinder at the top. From there, collapse in one side with a hammer and punch. This is a familiar trick to anyone who has ever had to remove a stuck seal. Basically, you just need to break the circle and it will come right free.
Corrosion and debris around the cooling water jacket. Yikes.... This was a running engine!
Just the bottom portion remained. Now we went after it with a large brass block and an air hammer from the back side.
Once everything was out we clean clean cleaned everything up, dealt with the corrosion and painted the inside of the water jacket to hopefully forstall this happening again any time soon.
Water pump was a little iffy.... Replaced the bearings and the impeller, cleaned everything up nice.
Alternator got stripped and cleaned as well as new bearings installed on him too.
Quickly got much better looking as well.
And back into the Hyundai from whence it came.
post #48 of 51 Old 05-27-2018
Igor, throw the 3rd switch.
First start after rebuild
stagg is offline
post #49 of 51 Old 05-28-2018 Thread Starter
Take that quiet suburban neighborhood! It's always a great leap forward once you animate the long idle engine.
Now all you need is engine mounts and a way to make the propeller twirl around.
post #50 of 51 Old 4 Weeks Ago
SV SF is home. Quite litterally.
Now its time to get back to work.
Forthcoming are: new electronics, solar, cushions, and rebuilt yanmar.
stagg is offline
Where do you find hull number? fharbison S2 3 08-29-2013 03:01 PM
Hull Number One D&M|22 General Discussion (sailing related) 6 11-03-2011 02:47 PM
Hull Number billdre O'Day 1 10-26-2009 05:09 PM
Hull number help, please thenrie General Discussion (sailing related) 4 06-25-2006 07:45 AM
Hull Number?? WillS General Discussion (sailing related) 1 01-05-2001 08:06 AM
