Nonsuch tiller - SailNet Community
post #1 of 7 Old 08-13-2019 Thread Starter
Nonsuch tiller
Hello all. Is a Nonsuch 26 available with tiller helm versus a wheel ? Or could it be (easily) converted to a tiller ? Thanks.
Prairie Sailor is offline
post #2 of 7 Old 08-13-2019
Administrator
Jeff_H's Avatar
Re: Nonsuch tiller
I don't believe that the Nonsuch 26 was available with a tiller. The geometry of the cockpit would suggest that a Nonsuch 26 can be converted to a tiller reasonably easily. That said Nonsuches reportedly develop pretty heavy weather helms on certain points of sail and so may not be a good candidate for tiller steering.
Jeff_H is online now
post #3 of 7 Old 08-14-2019
Re: Nonsuch tiller
My Nonsuch 30 (I believe all do) has an emergency tiller that fits over the rudder stock. So I think you could easily convert one to tiller operation if you want.
Mike
Currently: Heading to warm waters over the winter on a variety of boats.
mbianka is online now
post #4 of 7 Old 08-14-2019
S/V Caper Nonsuch 36
flyrod's Avatar
Re: Nonsuch tiller
Hi, I am certain the 22's are available with a tiller and believe the 26' is a well, I see no reason why a conversion would be a problem if desired. Mike is correct about the emergency tiller configuration for Nonsuch. The rudder is a semi balanced fin type and I have not experienced any excessive weather helm assuming correct sail trim on my 36' Nonsuch, however, I have a wheel so there is some mechanical advantage.
flyrod is online now
post #5 of 7 Old 2 Weeks Ago
Drinky Crow's Avatar
Re: Nonsuch tiller
Did a Nonsuch ever sail the ocean?
Drinky Crow is offline
post #6 of 7 Old 2 Weeks Ago
Re: Nonsuch tiller
A few have. One with and without crew. It's story was written about in the book WITHOUT RIVAL.
https://www.pinterest.com/pin/467952217504818808/
Though it's designed for coastal cruising the boats are tougher than the crews it seems.
"The Nonsuch series of boats are generally considered to be very sturdily built boats. In his review, Paul Howard states that two Nonsuches, David Philpott's "Serenity IV" and Brian Shelley's "Saci IV", were abandoned at sea, found floating months later, and were refurbished and are sailing today."[3]
Mike
post #7 of 7 Old 2 Weeks Ago
roverhi's Avatar
Re: Nonsuch tiller
If there is access through the deck for an emergency tiller you should be able to rig a tiller. I did my Pearson 35 using hollow bronze tube machined to the diameter of the rudder shaft, 1 3/4" in my case, with a solid 1 1/2" rod at the other end to take the tiller head. Used a 2" thick piece of UHMPE plastic bolted to the cockpit sole as a top seal and bearing for the shaft.
If you want to explore it, have a 1 7/8" tiller head I'm not using. Could be machined to 2" if needed. Also a 1 5/8"
roverhi is online now
