Fuel tank woes - Page 5 - SailNet Community
 2Likes
post #41 of 49 Old 04-01-2016
Courtney the Dancer
jrd22's Avatar
Re: Fuel tank woes
Most places around here don't stock those little ones Med. You might have to special order.
MedSailor likes this.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #42 of 49 Old 04-11-2016
Re: Fuel tank woes
Originally Posted by sailak View Post
Anyone notice the "oops" in my notation on the tank?
Is the "aft" arrow pointed forward?
Will you be resting the tank on top of some plastic pipes as Pacific Seacraft does, or will you have the tank resting on the bilge sides?
Lantau is offline
post #43 of 49 Old 04-11-2016 Thread Starter
Crealock 37
sailak's Avatar
Dock
Re: Fuel tank woes
There is split pvc in the bilge covering the keel bolts but the tank seems to "hang" from the four large screws that secure it in the bilge. The screws go through the right-angle tabs welded to the top of the tank (in the photo there is some cord tied between the tabs to use as handles).
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
sailak is offline
post #44 of 49 Old 04-12-2016
Re: Fuel tank woes
Mentioning the split pvc brings to mind my latest misadventure Cuting lengthways a piece of plastic pipe to slip over a waterline being cast into a concrete wall ..All went well until the table saw blade finished the cut, pipe contracted ,gripping the blade and shooting across the basement with parts of my thumb and forefinger Plastic surgery on Thursday will make things right but in the meantime I can't find my butt with either hand.
Capt Len is online now
post #45 of 49 Old 04-16-2016
Hush34's Avatar
Re: Fuel tank woes
I have the engineering drawings for the new one we had made by Best Fab in Florida. The tank only cost about $650. Easy removal and install. Actually picked up a couple of gallons over the factory design.
Indecision may or may not be my problem.
Hush34 is offline
post #46 of 49 Old 04-16-2016
Which keel does your boat have?
Davashcow is offline
post #47 of 49 Old 04-17-2016
Hush34's Avatar
Re: Fuel tank woes
The shoal draft version.
Hush34 is offline
post #48 of 49 Old 04-17-2016
I would love those drawings...in fact, maybe I'll just go ahead and get the tank made since mine is original.
post #49 of 49 Old 04-18-2016
Hush34's Avatar
Re: Fuel tank woes
I would love to send you the drawing but they will not all a PDF download on this site. PM me with your email address and I will send it to you. Would love to help....
p.s. I was really impressed with the fabricator and love the tank.
Hush34 is offline
Holding Tank Woes datswite Cruising & Liveaboard Forum 10 08-29-2014 05:24 PM
Clogged fuel filter woes - advice Dave_E Diesel 10 08-12-2014 08:48 AM
Other Yanmar 3 GM woes & fue4l tank saltypat Gear & Maintenance 2 04-07-2008 09:42 AM
Diesel Fuel Tank Woes...or Bonehead mistake of the season rperret Gear & Maintenance 9 10-07-2007 09:32 PM
fuel tank woes almostbroke Gear & Maintenance 2 12-08-2004 07:10 AM
HTML code is Off
