Hydrovane and motoring - SailNet Community
 1Likes
post #1 of 13 Old 01-06-2016 Thread Starter
Cruisin' for a Bruisin'
Has anyone installed a Hydrovane on a PS34 and if so, does it cause any problems when motoring? For example: helm bias, shuddering, etc.
Thanks,
-C
cshrimpt is offline
post #2 of 13 Old 01-07-2016
Re: Hydrovane and motoring
Thanks,
-C
I have a Hydrovane but not a PS34. We have a big engine and large prop and we found that the Hydrovane shuddered when motoring and broke the stainless steel locking pin.
On speaking to Derek Daniels, the designer, at the London Boat show, he suggested we made up a “tiller lock” that went into the little black stub tiller that the unit comes with. It is roughly "L" shaped and attaches to the pulpit rail.
This secures the unit went motoring, it still shudders at bit but does not break the stainless steel pins which, if I remember correctly, are about $20 - $25 each
Hope this helps
Triumphant is online now
post #3 of 13 Old 01-07-2016
outbound's Avatar
Tri
Thanks for the response. We are in the process of negotiations for one.
? Does this occur at all speeds?
? Can you post a picture of the tiller lock please? Ideally deployed and separate.
? Do you know if this is a problem with all Hydrovanes or has this issue been designed out? If so when?
? Is it worth talking to Will further about this?
s/v Hippocampus
Outbound 46
outbound is online now
post #4 of 13 Old 01-07-2016
My unit has 30,000 miles on it so it rattles a little anyway even at anchor. I have a 72 Hp engine with a 22 Inch prop about 6 feet away from it so it gets a good prop wash and yes it does occur at all speeds.
See attached?
See attached photos.
The pictures do not show it too clearly but the end of the lock has an eye in it, the Pulpit rail also has any eye welded onto it and a bolt drops through both holes and secures it. Hope these help
? Do you know if this is a problem with all Hydrovanes or has this issue been designed out? If so when? ?
I don’t know, my unit was purchased on 1997 so maybe ask other owners and ask the Hydrovane people. Derek did not seems surprised about it when I spoke to him about the problem
?? Is it worth talking to Will further about this?
Maybe yes, see above
The Following User Says Thank You to Triumphant For This Useful Post:
outbound (01-07-2016)
post #5 of 13 Old 01-07-2016
SV Skalliwag #141
brokesailor's Avatar
I have a Crealock 37 and it also vibrates. If it really bothers you, joyous can always remove the vane rudder when not in use. Don't let this keep you from getting the vane.
brokesailor is offline
post #6 of 13 Old 01-07-2016 Thread Starter
I'm surprised that after all these years they haven't figured out how to set up a mechanism that gets the tiller out of the water whenever you want. I understand it's easy to remove when underway, but pretty much impossible to put back on.
I looked at the Monitor, but it is too much of a Rube Goldberg like machine for my tastes.
-C
cshrimpt is offline
post #7 of 13 Old 01-07-2016
outbound's Avatar
We're kind of stuck on the Hydrovane as the first choice. It can be put off center and easily converts to an emergency rudder. I don't like the weight and complexity of the monitor swing gate.
I had a Fleming on a T37 so well familiar with servo pendulum devices. Liked the Fleming a lot but be a bear to put on the outbound. Looked at the others ( Sailomat etc.) but off the list for one reason or another. These things are a big expense for me and will only be done once so any info is greatly appreciated.
s/v Hippocampus
Outbound 46
post #8 of 13 Old 01-08-2016
Mermaid Hunter
SVAuspicious's Avatar
My personal experience is that it is a PITA to get off underway and a bigger PITA to get on underway. I can't imagine trying to get the rudder on while the boat is doing 7 or 8 knots.
Heaving to is my approach of choice. You are still going to get wet. There will be swearing involved. Don't drop anything.
Faster likes this.
SVAuspicious is offline
post #9 of 13 Old 01-08-2016
outbound's Avatar
So what's the verdict gentlemen?
~30k displacement, hard Bimini and have davits, sugar scoop with centerline swim ladder.
Figure we live two lives. Passages and once there coastal day hops. Strong believer it's a SAILBOAT not a stinkpot. So it will go on just for passages or when single handing.
Is the Hydrovane worth the bucks and a good choice?
s/v Hippocampus
Outbound 46
post #10 of 13 Old 01-08-2016
The Hydrovane was the choice of a friend of ours who took his Passport 40 to Mexico from the PNW. This is a very meticulous, detail oriented retired pilot who researched to the nth degree.
The off center mount was a big factor, I believe - centerline ladder too. Ultimately he was pleased with it, but in reality used the AP more, except on the longer runs and crossings. I don't believe he left the rudder on when not actively in use... abd I don't believe he ever tried to remove/replace it underway.
Faster is offline
The Following User Says Thank You to Faster For This Useful Post:
outbound (01-08-2016)
Hydrovane vs. Monitor erps Gear & Maintenance 11 07-18-2017 04:45 PM
PSC 37 Hydrovane Installation SVArgo Pacific Seacraft 3 10-14-2014 01:36 PM
No A/C when motoring? NickPapagiorgio General Discussion (sailing related) 34 08-03-2012 03:31 PM
Hydrovane? Rockter General Discussion (sailing related) 5 12-05-2011 05:30 PM
Hydrovane... Rockter Gear & Maintenance 20 07-10-2009 02:38 AM
HTML code is Off
