Bimini for PS34 - SailNet Community
post #1 of 8 Old 01-08-2016 Thread Starter
Cruisin' for a Bruisin'
Bimini for PS34
Are there companies that make Biminis that fit a PS34, or are Biminis in general something that's custom made? I've never bought one so I'm not sure how they are sourced.
Thanks,
-C
cshrimpt is offline
post #2 of 8 Old 01-09-2016
Re: Bimini for PS34
C,
I know there are some companies that offer off the shelf biminis, but there are so many different ways to do them, be sure you get what will work for you. We had the bimini on our PSC 34 custom made. Here are some of the considerations that were covered: 1. the height under the bimini while standing, 2. allow enough room to move between the bimini and our dodger, 3. we had to re-cut the main sail slightly (just a bit of the foot of the sail) to allow the boom to pass over the top of the bimini.
I have attached a photo to show you how our bimini turned out.
Steve
Pegasus34 is offline
The Following User Says Thank You to Pegasus34 For This Useful Post:
cshrimpt (01-09-2016)
post #3 of 8 Old 01-09-2016 Thread Starter
Re: Bimini for PS34
Thanks Pegasus, what you have is basically what I'm looking for. I'll see if I can find someone local who makes biminis.
-C
cshrimpt is offline
post #4 of 8 Old 01-22-2016
Hush34's Avatar
Re: Bimini for PS34
Hey Cschrimpt, Do you have a dodger? If not you might want to design the Bimini and the dodger together. Off the shelf Biminis might solve the problem, but I would say you would be best to contact a custom maker so you get what you want and need. There are so many variables in bimini design.
Indecision may or may not be my problem.
Hush34 is offline
post #5 of 8 Old 01-24-2016
svjobeth's Avatar
Re: Bimini for PS34
As has been said, it's important for bimini and dodger to work together. And I would strongly encourage you to have the bimini made by a canvas shop to fit your boat.
In the interest of full disclosure however, I should add JO BETH does not have a bimini. Since we have a radar mast aft, we use a cockpit awning. The awning zips across the rear of the dodger and has a sleeve at the aft end through which a stainless pole is used to 'hold it open in the back. The pole is tied to the backstay at a cut-out in the awning. A loop is in the center to keep the awning peaked. We can even sail with the awning in place, not peaked of course. ('Peaking' the awning uses the main halyard.)
It works for us with our configuration. No bimini legs in the way of the cockpit, etc. Not a great pic, but you get the gist...
Bill & Lisa Ballard
S/V Jo Beth
1984 Pacific Seacraft Crealock 34, Hull #16
"Twenty years from now you will be more disappointed by the things you didn't do, than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."
- Mark Twain
svjobeth is offline
post #6 of 8 Old 01-24-2016
Not Finished Yet
RainDog's Avatar
Re: Bimini for PS34
We use a very similar setup to Jo Beth. My boat came with a conventional Bimini, and I hated it for a number of reasons. When we added the dodger we did a similar awning that attaches to the dodger and the backstay. I find it far better than a conventional Bimini. It is more versatile, out of the way when stowed, no poles to make getting out of the cockpit less safe, and it is much cheaper.
RainDog is offline
post #7 of 8 Old 01-24-2016
Crealock 37
sailak's Avatar
Dock
Re: Bimini for PS34
Elnora also has a cover similar to JoBeth's. Only real con I find is since it is attaced at the center to the boom to "tent" it can't be used while under sail.
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
sailak is offline
post #8 of 8 Old 01-25-2016 Thread Starter
Re: Bimini for PS34
I do have a dodger so I want them to work together. There are a couple of local canvas makers that I'll have take a look.
Thanks,
CS
S/V Wayfinder - 1985 Pacific Seacraft 34
cshrimpt is offline
Rigging guide for PS34 cshrimpt Pacific Seacraft 4 11-05-2015 12:27 PM
What head will fit in a PS34? oceangirl Pacific Seacraft 20 07-31-2011 02:05 PM
Recommended Sailmakers for PS34 retomas Pacific Seacraft 5 03-24-2011 09:55 AM
PS34 Bathroom Door BobbyBrown Pacific Seacraft 6 11-11-2008 06:35 AM
HTML code is Off
