Replace Cowls on PSC 34 - SailNet Community
post #1 of 5 Old 01-14-2016 Thread Starter
Good morning folks
Replacing cowls on my 1990 PSC34 is high on my spring to-do list. Does anyone have experience doing this? Any guidance would be greatly appreciated.
chrisryba is offline
post #2 of 5 Old 01-14-2016
Re: Replace Cowls on PSC 34
The rubber (or plastic ?) dorade cowls on my boat had apparently been painted repeatedly and looked bad, so I stripped off the old paint with paint stripper and repainted them with white spray paint from a can, and they look new. After 3 years, they still look good, but, if they get bad again, it's an easy winter task to strip them and re-paint them.
Sailormon6 is online now
post #3 of 5 Old 01-15-2016
Location: The house is in Kingsport, TN. Boats are on Watauga Lake and in New Bern, NC
On the advice of Will Heyer at Vetus, I scrubbed my Vetus PVC crowls with soap, water, and bleach to get the crud off, wiped them with acetone and clean cloths to remove any surface plasticizer that would interfere with the paint, masked first the inside then the outside, and painted them red on the inside an white on the outside with Krylon Fusion paint. When it needed to be done again after a couple of years, the old Krylon came off with acetone.
Bill Murdoch
1988 PSC 34
Irish Eyes
wsmurdoch is online now
post #4 of 5 Old 01-15-2016
Hush34's Avatar
I too have old a worn cowls. I have the vetus brand. I measured and the measurements don't match the current design. Are you having the same problem?
P.S. I can't budge the rings that would release the vents from the base. I have managed to compress the vent enough to get it off the base.
Indecision may or may not be my problem.
Hush34 is offline
The Following User Says Thank You to Hush34 For This Useful Post:
chrisryba (01-18-2016)
post #5 of 5 Old 01-15-2016
jvlassak's Avatar
I got a couple of new cowls from Vetus last year. They came with plastic rings that didn't fit the base well. So I removed the cowls from the rings and used the old rings. That worked well enough as the new cowls were the same size as the old ones. But it didn't take long for the new cowls to start turning gray.
jvlassak is online now
The Following User Says Thank You to jvlassak For This Useful Post:
Replace Panel vs. Replace Switches geronimo69 Electrical Systems 12 12-11-2013 12:44 PM
PSC cockpit shower replace Drifting Pacific Seacraft 4 09-30-2009 04:10 PM
Air Cowls backcreeksailor Gear & Maintenance 5 04-09-2009 01:11 PM
Repainting Cowls jobrantley Gear & Maintenance 15 08-15-2008 05:50 AM
used PSC-34's x 2 in san diego, x 1 PSC-31 in dana point AlexHazzard Pacific Seacraft 0 08-18-2007 01:44 PM
HTML code is Off
