damaged non-skid - SailNet Community
 1Likes
  • 1 Post By midwesterner
post #1 of 6 Old 04-20-2016 Thread Starter
damaged non-skid
My boat was launched today but I was not present. I went to check on it after work and was very dismayed when I noticed the damage shown in the photo - it appears that the yard personnel may have inadvertently uprooted one of the mounting brackets on the cockpit coaming for my bimini. Adding insult to injury, it was raining when I discovered the damage so there is undoubtedly water in there.
In the event that the marina doesn't fix it for me, I will have to do it. I'm guessing the holes should be filled with epoxy and then re-drilled. Anyone have a similar experience, or any suggestions?
kbbarton is offline
post #2 of 6 Old 04-21-2016
Freedom isn't free
Dock
Re: damaged non-skid
The good news is, it was bedded with silicone... so you'd want to fix that anyway
I wouldn't worry a lot... check for water underneath, and yes, I'd over-drill and fill the holes, then drill them again. Then you'll need to clean that silly-cone off. Brass brush, or wire brush... or like TakeFive did in his chainplate thread, use a wire wheel on a drill, and tape it off. Trick is to get all the silly cone off.
Then taper the holes, rebed with butyl tape, and be done.
Freedom, a 1983 C&C 32 sailing Smith Mountain Lake, VA
SHNOOL is offline
The Following User Says Thank You to SHNOOL For This Useful Post:
kbbarton (04-23-2016)
post #3 of 6 Old 04-21-2016
midwesterner's Avatar
From the look of it, I'm thinking that it might not be the fault of the yard staff. There is water staining around the area. It's possible the screws were rusted and we're ready to go soon anyway. They might have just bumped it and it was time to go. That suggests that you will want to check the others.
SHNOOL likes this.
midwesterner is online now
The Following User Says Thank You to midwesterner For This Useful Post:
post #4 of 6 Old 04-21-2016
After cleaning up silicone, you might be able to countersink, butyl and through bolt...if you can get under coaming and jaw fitting covers.
captjcook is offline
The Following User Says Thank You to captjcook For This Useful Post:
post #5 of 6 Old 04-23-2016 Thread Starter
Thanks for the feedback! When you say "taper" the holes, do you mean use a countersink bit to create an impression around the hole for the butyl tape to fill?
Before that though, the holes need to be filled then re-drilled. It has been a few days since it rained here, but the temp has only been in the 40's F. Do you think that is enough time for the wood core to be reasonably dry, or should I have a hairdryer on it for awhile? I tend to get really concerned about water intrusion in the core material because I had a large section of deck that was delaminated when I bought the boat and it was a very expensive affair!
Now to buy some epoxy and butyl tape....
kbbarton is offline
post #6 of 6 Old 04-23-2016
amwbox's Avatar
Check these out:
https://youtu.be/2eZLorXTNys
https://youtu.be/UpsRljqBH0o
A LOT of good stuff on this guy's channel.
"Freedom is the increased knowledge of what you can do without." —Thoreau
amwbox is offline
The Following User Says Thank You to amwbox For This Useful Post:
Non Skid Norumbega Gear & Maintenance 10 01-02-2012 10:21 PM
Non-skid recommendations prroots Gear & Maintenance 4 01-02-2012 07:53 PM
Painting non-skid MarkSF Gear & Maintenance 5 11-14-2011 02:56 PM
Non-Skid color ToppDogg General Discussion (sailing related) 4 06-19-2011 02:41 PM
No skid. Tweegs Gear & Maintenance 8 06-04-2011 12:25 PM
HTML code is Off
