Driveline vibration when engine is off - SailNet Community
post #1 of 16 Old 04-21-2016 Thread Starter
Sailed my new-to-me 1988 PSC34 for the first time over the past couple days in some pretty good wind. When the boat accelerates through six knots or so under sail, you can see the engine tremble as the prop really gets spinning. (Engine off, transmission in neutral) Probably less than a quarter inch of displacement twice per second. When the boat slows back down due to less wind or eased sheets, the vibration stops and the prop just makes it's quiet "thump-thump" noise. The prop is an 18-inch two-blade job that's freshly balanced. Thoughts?
Davashcow is offline
post #2 of 16 Old 04-21-2016
Old as Dirt!
svHyLyte's Avatar
Re: Driveline vibration when engine is off
Pull your engine into reverse gear to stop the prop "freewheeling". (Alternately, you can add a shaft lock but that's rather more effort than really necessary.)
svHyLyte is offline
post #3 of 16 Old 04-21-2016
Yes... except that some manufacturers definitively say not to do so, so check.
Faster is offline
post #4 of 16 Old 04-21-2016
Rob Patterson's Avatar
It seems tha t a folding prop is desired here
Rob Patterson is offline
post #5 of 16 Old 04-21-2016
Old enough to know better
Really nice boat, I would check to see if there is a shaft break. Depending on the location of the engine/transmission. Different set ups look different. Some are like a box over the shaft, others are just basically a stick you put into a slot to hold the shaft in place. If you have a 2 blade prop it will likely line it up with the keel/rudder. Feathering/folding props are great but quite expensive, and can add a bit of complexity to the system.
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
post #6 of 16 Old 04-21-2016 Thread Starter
I found info that says Kanzaki gearboxes are to be left freewheeling.
I'm just curious if other PSC guys/gals have any vibration as I've described.
post #7 of 16 Old 04-21-2016
krisscross's Avatar
Is is supposed to vibrate that much with a 2 blade prop? Maybe a 3 blade prop would do better.
Plato
krisscross is offline
post #8 of 16 Old 04-22-2016
BMLipiec's Avatar
We have a 3 blade max prop and when sailing I can noticeably hear and feel the prop spinning until I shift into reverse, feathering the prop. Assuming your engine alignment is good, then the noise and vibration you are feeling is probably normal.
Brian & Marya
S/V Indigo
Pacific Seacraft 34
Hull #281
BMLipiec is offline
post #9 of 16 Old 04-22-2016
The way to stop a Max Prop from free wheeling is to kill the engine while still motoring in forward. The forward motion of the boat feathers the blades. You can leave it in forward or put it in neutral. The prop should not be spinning, if it is, you've defeated the reason for buying a feathering prop.
Shockwave is offline
post #10 of 16 Old 04-22-2016
Old as Dirt!
svHyLyte's Avatar
We locked our Kanzaki transmission (on a 2GM20FW) in reverse to prevent freewheeling for 15 years without difficulty.
FWIW...
svHyLyte is offline
Little bit of corrosion on the driveline? Jgbrown Gear & Maintenance 2 10-14-2013 05:32 AM
Loud whine in driveline at low RPM straitdave2 Atomic 4 7 10-03-2009 01:00 AM
Mystery engine vibration, gear box failure? WindermereColvic Diesel 8 09-04-2009 09:46 AM
Engine vibration between 1100-1200 RPM - Normal? zAr Gear & Maintenance 8 07-04-2009 12:49 AM
Catalina 36 engine vibration CatalinaFan Boat Review and Purchase Forum 2 09-28-2007 07:01 PM
HTML code is Off
