Should I ditch the refer on my PSC34? - Page 3 - SailNet Community
 4Likes
post #21 of 28 Old 07-16-2016
One of None
deniseO30's Avatar
Re: Should I ditch the refer on my PSC34?
Originally Posted by Interlude View Post
Hey Denise, We are very happy with our current refridge system. Just threw out the Engel units for the OP that was considering something different. No measurements,photos, or install advice coming cuz we aren't doing one! Good advice for someone if they do though.
Sorry my bad,. "senior moment". All the hair splitting every one does about the 12/24 volt units when it's clear how incredibility efficient All of them are makes me
My last project!
deniseO30 is offline
post #22 of 28 Old 07-16-2016
S/V Interlude, PSC31
Smile Re: Should I ditch the refer on my PSC34?
I hear ya! We are simply happy to have refrigeration of any type, especially in an icebox as well designed and insulated as the one on our boat. PSC didn't scrimp on it's construction.
Interlude is offline
post #23 of 28 Old 07-16-2016
roverhi's Avatar
Lived aboard for 3 years, cruised to SoPac and recently solo'd to Hawaii without refrigeration. Buy better quality beer and you don't need it. Used block Ice when we were living aboard and it would last for 3 days or so not a big deal to replenish. Didn't bother to buy ice with current board that I've lived on for weeks at a time and sailed to Hawaii. Fresh stuff kept for 3-4 days in SF without refrigeration and everything tastes better at room temp in any case. Cruising wasn't an issue as only a freezer would solve long term storage issues. Fresh veggies weren't readily available so a reefer would have been virtually useless except for beer in any case if you are going off the beaten path. The only I missed was a glass of cold milk occasionally which would have run out quickly on a passage.
Maintaining refrigeration seems to be a major headache for boats with it. Seems like the refrigeration owned the boat's owners. When it went down, which it seemed to do quite often, they'd immediately pull up the anchor and sail hundreds of miles and hang in some polluted commercial harbor waiting to get it fixed. Knew several boats that blew through the Marquesas and Tuamotu's virtually without stopping so they could get their refrigeration fix. Missed some of the best cruising out there just so they could have a cold beer.
Refrigeration is a nice to have item for cruising but certainly not a necessity. Like all the other toys on a boat, the more you have, the more time you spend keeping them going almost to the point where they become your full time occupation. Almost left out the most important negative for refrigeration, the systems eat electrons like there is no tomorrow. You'll definitely need a couple amps of battery stowage, several hundred watts of solar, and a wind generator dedicated to keeping the reefer cold. It's either that or run the engine every day or install a generator.
Lazerbrains likes this.
roverhi is online now
post #24 of 28 Old 07-16-2016
One of None
deniseO30's Avatar
12/24 volt refrigeration came out I think, in the early 80s VERY LOW WATTAGE! VERY DEPENDABLE! AMAZING in most everyway compared to engine driven and 120/220 volt or even 3 phase.
You may be taking all the discussions here as trouble but most are about making the ice boxes better.
You are entitled to your own opinion but in this I say distinctly you are wrong. A machine that draws 3-5amps on 12 volts is nothing short of amazing.
Boats with just 2 12 volt batteries can run the fridge on 1 bat for 2-3 days
Some boats are still running units installed in the early 80s and it helped me sell my boat!
My last project!
post #25 of 28 Old 07-16-2016
midwesterner's Avatar
Yeah, rip that refer system out. You don't really need it. Ice should work fine.....
Then you can sell it to me cheap since it's used because I'm looking at a boat that only has an ice box and I'd like to have a carton of milk for my cereal, and cold beer, and not have to worry about draining the water out of ice box every few days.
deniseO30 likes this.
midwesterner is online now
post #26 of 28 Old 07-18-2016
bell ringer
Don L's Avatar
[[email protected];3582393
Maintaining refrigeration seems to be a major headache for boats with it. Seems like the refrigeration owned the boat's owners. [/QUOTE]
One of those internet forum myths. In 8 years and two boats (one with a 25 year old refrigeration system and one with a 15 year old system) never have had any problem with my freezer/refrigeration. The only "maintenance" needed is defrosting once in a while.
Meanwhile my boat is out on it's mooring with the refrigeration running 24/7 keeping the beer cold, the frozen food frozen, and the cold cuts cold!
I sure don't miss the days of lugging ice to the boat and every time I wanted to be away a while having to get rid of food needing cold storage.
Don't blow air up my rear, be useful and blow it at the sails!
Don L is online now
post #27 of 28 Old 07-18-2016 Thread Starter
Cruisin' for a Bruisin'
Originally Posted by deniseO30 View Post
Another op that disappeared...
I'm here and read every word thank you very much.
Shrimp
S/V Wayfinder - 1985 Pacific Seacraft 34
cshrimpt is offline
post #28 of 28 Old 07-24-2016
Originally Posted by cshrimpt View Post
My 34 came retrofitted with an Adler Barbour Cold Machine. While it's nice to not have to deal with ice, I think it takes up too much room in the ice box. I'm thinking either I should just take it out, or switch the evaporator with the flat cold plate since the freezer part is useless although I do like the giant ice cubes it makes.
What do you think? Switch to a flat plate or ditch the whole thing.
Thanks,
Shrimp
Hey Shrimp, responded earlier with a suggestion to look at Engel units but reread ur original inquiry and needed some clarification. We also have a PSC, an 89 31 and so our icebox is as well constructed as yours. The Adler Barbour refer was not installed until 98ish by the previous owner. Other than the freezer, which works like a champ, there is no intrusion into the ice box space. Certainly takes up less room than multiple blocks of ice and has the added benefit of space used for food instead of melting ice. Is your set up different?
Interlude
Ditch bag vs Ditch box mad_machine General Discussion (sailing related) 6 10-19-2014 01:15 PM
Refer seals for lids? SanDiegoChip Gear & Maintenance 7 03-14-2011 07:14 PM
Refer line blew watom Gear & Maintenance 1 03-16-2009 10:23 AM
allied refer upgrade mynewlife Gear & Maintenance 2 03-09-2009 02:25 PM
refer question kwas General Discussion (sailing related) 5 08-28-2006 09:36 PM
HTML code is Off
