What size deck fill O ring for 80's Crealock 34? - SailNet Community
 1Likes
  • 1 Post By albrazzi
post #1 of 6 Old 09-18-2016 Thread Starter
Cruisin' for a Bruisin'
All,
Looking for an O ring for my water fill on a 85 Crealock 34. I'm having difficulty finding the right size as the one that broke is missing a chunk and I can't measure it. I don't want to remove one of the other one's if I can figure it out here.
Anyone know the size for the deck fill O ring? It looks like it is close to 1 11/16 OD x 1 7/16 ID x 16, but I can't tell for sure. Love to figure this out before it rains.
Thanks,
Shrimp
S/V Wayfinder - 1985 Pacific Seacraft 34
cshrimpt is offline
post #2 of 6 Old 09-19-2016 Thread Starter
Re: What size deck fill O ring for 80's Crealock 34?
In case anyone's ever asking the same question, it appears to be a 1 1/2 x 1 3/8 x 1/16 #56 O ring.
Shrimp
cshrimpt is offline
post #3 of 6 Old 09-26-2016
s/v Pelagic
Assuming the deck fills on the 1980 C34 are the same as the C37, I found a source at: allorings.com. The p/n I used was B1000-029 for BUNA-N O-rings. The bad news is the minimum order quantity was 100 pieces (a lifetime supply for me). The good new is I think the total was $10 or $15. This was at least 15 years ago so YMMV. You can request a quote on their website.
John
s/v Pelagic
1980 C37 Yawl
jnewcomer is offline
post #4 of 6 Old 11-27-2016
svjobeth's Avatar
Just saw this thread - and am away from the boat at the moment, so I don't have the specs - but I found the O-rings I use at a local mom & pop hardware store. I bought a dozen for around $3, if memory serves. However, I was able to take an old one with me to match sizes.
Bill & Lisa Ballard
S/V Jo Beth
1984 Pacific Seacraft Crealock 34, Hull #16
"Twenty years from now you will be more disappointed by the things you didn't do, than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."
- Mark Twain
svjobeth is offline
post #5 of 6 Old 11-27-2016
al brazzi
Hardware or local hydraulic hose shop. GOOGLE Parker hydraulics. All towns of any size have a hydraulics shop, they are not too protective of dealing with the public like some wholesalers.Take the cap with you and match it up.
RichH likes this.
albrazzi is offline
post #6 of 6 Old 11-27-2016
RichH's Avatar
Don't measure the O-ring !!!!!! They deform (shrink or 'swell' - that can easily change the ID/OD /'thickness') over time when under pressure and chemical contact.
Measure the ID of where the O-ring fits into the removable deck plate cap; then, measure the OD of the groove where the O-ring comes in contact with the non-removable deck fill. Use a 'caliper' if you have one to measure.
Subtract the measured ID from the measured OD .... then divide the result by two to get the approximate 'thickness' of the O-ring to the 'nearest' 1/32".
If you have any suspicions that the fuel delivery may contains 're-claimed' so-called bio-fuels (can be quite common in times of high fuel prices), then consider to install a VITON™ O-ring. Viton™ (expensive!!) is chemically compatible with the very aggressive 'acids' that contaminate bio-fuels; BUNA, Neoprene, etc. are not compatible, especially with fuel blends containing bio-fuels made from 're-claim'.
Consider the 'softness' (durometer) of the O-ring. 70-durometer is standard; the 'softer' 50-durometer seals better but needs to be replaced more often.
Here's a detailed listing for conversion of sizes (inches) to 'standard' O-ring SIZE & thickness designations. http://catalog.precisionassoc.com/as...ustrations.pdf ..... you start with thickness, then ID/OD.
'Grainger' and other online industrial supply sources have these O-rings; so does Amazon, eBay, etc.
RichH is offline
The Following User Says Thank You to RichH For This Useful Post:
MastUndSchotbruch (11-27-2016)
Deck fill cap measurements okapi3 Pacific Seacraft 5 09-28-2012 10:54 PM
Looking for Deck Fill Plugs ewoden Gear & Maintenance 1 09-23-2012 11:43 AM
deck fill cap for Pearson 32 Outrageous Gear & Maintenance 6 08-30-2012 04:41 PM
Deck fill plugs tiami82 Gear & Maintenance 3 07-18-2011 09:36 AM
Prop Size for Crealock 37 w Yanmar 4JHE MarcHall Pacific Seacraft 0 07-19-2010 10:58 AM
HTML code is Off
