PSS shaft seal - Page 2 - SailNet Community
 3Likes
post #11 of 17 Old 10-26-2016
Re: PSS shaft seal
Regardless of whether you use a split coupling or solid coupling, it should be fit to the shaft by a machine shop and faced to run true with the shaft.
sesmith is offline
post #12 of 17 Old 10-26-2016 Thread Starter
jvlassak's Avatar
Re: PSS shaft seal
That is what I originally assumed and that would require removing the shaft. I wonder if there is even enough space to slide the shaft back into place without removing the gearbox once the coupling has been fitted - that takes us back to a flexible coupling that can tolerate minor misalignment.
Is there anyone who has experience with flexible couplings?
1995 Pacific Seacraft 34
Iphigenia
jvlassak is online now
post #13 of 17 Old 10-26-2016
One of None
deniseO30's Avatar
Re: PSS shaft seal
"drive saver" is the shortest one as it just fits between the flanges. The alignment still needs to be close or any flex coupling will have a shorter life.
Most of the worry and pre project anxiety is worse then the work. Even dropping a rudder is not that difficult.
Is the cutlass bearing loose?
My last project!
deniseO30 is offline
post #14 of 17 Old 10-26-2016 Thread Starter
jvlassak's Avatar
Re: PSS shaft seal
The cutlass bearing is pretty tight, little or no motion in the shaft. I get it about the pre project anxiety - you're dead right on that one.
Iphigenia
post #15 of 17 Old 10-26-2016
Re: PSS shaft seal
Probably 20 years on our PSS shaft seal. It still looks good but we will replace this year along with the cutlass bearing. It lasts a long time but considering the litigious society we live in it probably drives the maker to build in a VERY healthy safety margin.
gonecrusin is offline
post #16 of 17 Old 10-26-2016
One of None
deniseO30's Avatar
Re: PSS shaft seal
Knowing a bit about drives, seals, pumps etc the way PSS doesn't leak is still amazing to me
My last project!
post #17 of 17 Old 12-17-2016
Re: PSS shaft seal
I have not been on the forum for more than a year. I sail #274 PSC34. Three years ago I changed the prop, the cutless bearing, the stuffing box into a PSS, and the coupling into a split coupling. I did not drop the rudder. I prepared a detailed work plan and if you are interested to have it, PM me. I did not use a workshop for coupling/shaft alignment.
YankeePSC34 is offline
PSS Shaft Seal DCSailor1 Gear & Maintenance 9 09-09-2015 03:30 PM
Pss Shaft Seal Magic1 Gear & Maintenance 16 10-07-2010 01:03 AM
Who has PSS shaft seal installed? orientalnc2010 Pacific Seacraft 6 04-25-2010 06:03 PM
PSS shaft seal Windborn Gear & Maintenance 26 02-01-2009 10:10 PM
Packless Shaft Seal (PSS) bkdehuff General Discussion (sailing related) 4 04-20-2004 05:41 PM
HTML code is Off
