Propeller pitting - Page 4 - SailNet Community
 9Likes
post #31 of 36 Old 02-03-2017
I don't discuss my member
Fstbttms's Avatar
Re: Propeller pitting
Originally Posted by kbbarton View Post
I need to de-grease it before shipping it to PYI. Anyone have a recommendation for how I can do that?
A bunch of paper towels.
Fstbttms is offline
post #32 of 36 Old 02-03-2017
BMLipiec's Avatar
WD-40 works well to get off the grease and then wash with Dawn dish detergent to remove the WD. Also, most boat yards have a parts cleaning station for degreasing parts.
Brian & Marya
S/V Indigo
Pacific Seacraft 34
Hull #281
BMLipiec is offline
The Following User Says Thank You to BMLipiec For This Useful Post:
kbbarton (02-04-2017)
post #33 of 36 Old 02-03-2017
It's hard to wipe all the gears, etc. I will still be full of grease. I like this stuff. I buy it by the gallon and use if for everything from degreasing to laundry. It is exactly what I used, when I sent in my prop. Biodegradable and non-toxic.
https://www.amazon.com/Oil-Eater-Cle.../dp/B000EALHH6
Get a cheap parts cleaning brush too.
Jeanneau 54DS
Minnewaska is offline
The Following User Says Thank You to Minnewaska For This Useful Post:
post #34 of 36 Old 02-03-2017
Towguy's Avatar
Brake cleaner works well on greasy parts if you don't have access to a parts washer...
Northern Alberta. "85" C/L 16. ,"85"S2 7.9 under repair.
Towguy is offline
The Following User Says Thank You to Towguy For This Useful Post:
post #35 of 36 Old 02-03-2017
fallard's Avatar
After consultation with the folks at PYI, looks like I am going to send the propeller in to be reconditioned. I found a handy video on disassembling a three-blade Classic. I need to de-grease it before shipping it to PYI. Anyone have a recommendation for how I can do that? I know industrial de-greasers are extremely toxic and nasty to work with, but I'm curious what my fellow sailors use on their boats.
You could get a disposable chip brush and some gasoline. Swab the disassembled parts with the gasoline after wiping the bulk grease with paper towels. Contain the gasoline in an empty tin can and dispose of it properly.
Otherwise you might take it to a local garage and let them degrease it.
fallard is online now
The Following User Says Thank You to fallard For This Useful Post:
post #36 of 36 Old 02-03-2017
al brazzi
Brakleen is non flammable in the red can, non flammable is good.
Towguy likes this.
albrazzi is offline
The Following User Says Thank You to albrazzi For This Useful Post:
Bronze prop pitting filing Val v Maintenance/How-to Videos 19 01-03-2016 11:01 AM
Propeller q brak Gear & Maintenance 13 02-11-2009 07:46 PM
What is your propeller ? negrini Gear & Maintenance 12 06-19-2008 10:05 AM
Propeller Identification DDawe Gear & Maintenance 1 05-07-2008 09:11 AM
Mast pitting jsutor Gear & Maintenance 2 02-13-2004 04:09 AM
HTML code is Off
