Reroute engine "stop cable"? - Page 2 - SailNet Community
 3Likes
post #11 of 18 Old 01-19-2017
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Re: Reroute engine "stop cable"?
I have a Yanmar 2GM and the stop cable is on the panel in the cockpit. It was recommended to me that I move it off the panel. The reason was the panel lifts a little when pulling on the cable and could break the seal on any bedding used around the panel.
You could probably just put it anywhere convenient, for regular use, and/or in an emergency.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
post #12 of 18 Old 01-19-2017
Barquito
Barquito's Avatar
Under the seat would be a lot better than where my choke pull (same knob as diesel kill) is located. Mine is on the bottom of the side seats. When heeled, we need to dance around a little to avoid stepping on the thing. Our ignition switch is inside the cabin.
Valiant 32
Barquito is online now
post #13 of 18 Old 01-19-2017
Noah's Bosun
Cap-Couillon's Avatar
Anywhere you can reach it with reasonable ease and out of the way enough to avoid getting around the cockpit. Don't overthink it...
Would not go to electric even if it were an option... Most solenoid stops need to be energized to open the fuel shutoff valve on the injector pump. As the draw is pretty good, they will usually also have a relay to pass the higher solenoid current. Switch failure, relay failure, solenoid failure, or power failure will kill your iron genoa. 9 out of 10 diesel gensets I work on that have starting issues are related to the fuel shutoff (which for remote operation) is usually electric.
Mechanical guages... Mechanical fuel shutoff... Mechanical Throttle control... No lies, and easy to rig busted stuff in an emergency.
Just sayin
olson34 and albrazzi like this.
"If the wind will not serve, lay to the oars"
Cap-Couillon is offline
post #14 of 18 Old 01-20-2017
Hush34's Avatar
Going to Hush today, will get a pic.
Indecision may or may not be my problem.
Hush34 is offline
The Following User Says Thank You to Hush34 For This Useful Post:
chrisryba (01-23-2017)
post #15 of 18 Old 01-20-2017
Hush34's Avatar
Chris, Sounds like you are having the same problem I had with Hush. Our pedestal was in poor condition too. The biggest problem we had was not having the ability to change the steering cable should a break occur. The housing for the throttle and clutch welded it's stainless flat head screws to the aluminum housing and there was no breaking them free. We considered going to a tiller, but the Admiral wasn't too keen and even threatened to never take the helm as long as she had to steer with a "stick." After a considerable amount of research I contacted Edson and ordered a Vision series pedestal. It is the newer more modern version that integrates the hand hold into the pedestal itself. It comes standard with a very nice console to install a Nav Plotter. I am not installing an outdoor MDT instead we have ours at the nav station. Underway, we use a iPad for viewing and control. Works for us and I don't have to worry so much about theft or damaging seawater. I will try to send some pictures for you to see what we did. Until then take care.
Hush34 is offline
chrisryba (01-21-2017)
post #16 of 18 Old 04-07-2017
S/V Interlude, PSC31
Kinda late to this, but just rerouted our Yanmar stop cable because it frankly was corroded and suspect, also on pedestal where maybe could be tempted to reach though wheel in emergency (thought about that once already!) Anyway it ended up in the Starboard combing/winch handle box. short route, out of weather, close at hand, not likely to snag on anything.
Pondering new pedestal someday but just replaced all the cables and chain for the steering so will live with the nonstandard sized grab bar, no longer being made, Merriman. It's pretty solid just old. Kinda like the rest of our boat!
Interlude is online now
post #17 of 18 Old 04-08-2017
SanderO's Avatar
Depends on architecture / ergonomics of the boat and how you typical motor.
Mine is on a recess next to the engine instruments on the stbd coaming. It's not reach able from behind the helm... but I don't see stopping the engine needs to accessible from the helm per se. On my boat I've never felt there would be a better place. YMMV
SanderO is online now
post #18 of 18 Old 04-09-2017
fallard's Avatar
My panel was replaced a few years ago because it was cracked where the engine stop was located--obviously due to stress when activating the stop cable. When the new panel was installed we mounted the stop cable directly to the fiberglass to the right of the panel.
The ordinary location was to the right of the R in Yanmar on the factory panel, but the new panel had the same weakness as the old. Dumb design by Yanmar!
Rhapsody-NS27 likes this.
fallard is online now
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 05:31 PM
Cable connector "hood" necessary? josrulz Electrical Systems 2 02-07-2012 10:38 PM
Centerboard Stop Pin - What to "Glue" it with? Perithead Gear & Maintenance 3 01-19-2012 03:09 PM
Navico WP5000 Autopilot "beeps non stop" Stephane99 Gear & Maintenance 5 03-13-2011 07:03 AM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
HTML code is Off
