On a 34...how to clean the space beneath the stove... - SailNet Community
 2Likes
  • 1 Post By ianjoub
  • 1 Post By wsmurdoch
post #1 of 8 Old 02-19-2017 Thread Starter
svjobeth's Avatar
Living aboard a 34 full-time means you clean a lot...small spaces can become cruddy quickly. However, the space beneath the stove is quite hideous - and has presented us with access issues to clean up not only our own cooking grime, but that of our predecessors.
We'll likely have to replace the old stove/oven at some point in the future, and of course at that time, we can do a deep scouring...but until then my fellow 34 owners - and others - any tips?
Bill & Lisa Ballard
S/V Jo Beth
1984 Pacific Seacraft Crealock 34, Hull #16
"Twenty years from now you will be more disappointed by the things you didn't do, than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."
- Mark Twain
svjobeth is offline
post #2 of 8 Old 02-19-2017
One of None
deniseO30's Avatar
Re: On a 34...how to clean the space beneath the stove...
Assuming the stove you have is gimbled. It should lift up and out,
My last project!
deniseO30 is offline
post #3 of 8 Old 02-19-2017
al brazzi
As Denise said should lift out. Mine (force 10) has a spring clip to depress and lift straight up. Its a little awkward for one person but your galley might be larger than mine so you might have room for help. Of course you need to disconnect the Gas, if so equipped, and pressure test afterwards (to do it right) when reconnected.
albrazzi is offline
post #4 of 8 Old 02-19-2017
Household bleach and h2o2 will be your friend.
Ventilation and access to keep crud from gathering...
RegisteredUser is online now
post #5 of 8 Old 02-19-2017
Learning the HARD way...
eherlihy's Avatar
Clorox Cleanup is awesome for cleaning and deodorizing. Be careful with it though, as it obviously contains bleach.
eherlihy is online now
post #6 of 8 Old 02-19-2017
Land lubber
German cockroaches will eat everything edible (and some not edible things) that may collect there. Import a few of them!
Bigbluefl likes this.
ianjoub is offline
post #7 of 8 Old 02-20-2017
Location: The house is in Kingsport, TN. Boats are on Watauga Lake and in New Bern, NC
Here is an un-staged, un-cleaned, un-retouched photo of the space under our stove after living aboard underway for about a month. The stove is a Seaward Hillerange Princess two burner LPG stove with oven.
Originally the installation had a single hole to lock the stove level and keep it from swinging. On our trips to the Bahamas with four jugs of fuel on the starboard rail, the quarter berth filled with beer and Diet Coke, and the aft water tank full, the boat took on a decided list to starboard. Anchored, it was hard to fry an egg and the pancakes were oddly shaped. I made the stainless steel sector you see with nine holes so I could lock the stove level at anchor no matter what the boat's heel. Later, I added a tenth hole way back to lock the stove in its full swing position to clean under the stove and to give me better access to the tea kettle, the tea pot, the griddle, and the Nordic waffle iron (in the blue fleece bag) that are stored under the stove.
A quick wipe with 409 or similar keeps it clean; Bar Keeper Friend for the dried on grease (as well as making stainless steel shine). I tend to avoid the Clorox stuff because it corrodes steel, and the parts of the stove you can't see are steel.
Bill Murdoch
1988 PSC 34
Irish Eyes
https://cms.winlink.org:444/maps/Pos...%20for%20AK4PO at the red drop.
Irish Eyes to the Bahamas
stipakb likes this.
wsmurdoch is online now
post #8 of 8 Old 02-22-2017 Thread Starter
svjobeth's Avatar
Thank for the replies all - of course, we're trying to accomplish this w/o removing the stove/oven...
That said, I should have noted that the stove we have was not the 'stock' stove which came with the boat - or I can't imagine it would have been. It's a 3-burner top with oven/broiler, and is too big for the space, technically speaking. On the gimbals, it doesn't swing properly without impacting the structure behind the stove. The third burner is useless; a pot won't fit on it because it's too close to the joinery. We can't light it, because it's too close to the joinery.
We'll explore some these suggestions and see what happens. When we do replace it, it will be with a smaller, two burner unit.
Thanks again -
Bill & Lisa Ballard
S/V Jo Beth
- Mark Twain
svjobeth is offline
Empty sailboat stuck beneath Hampton Blvd. bridge - wtkr.com NewsReader News Feeds 0 03-13-2014 10:30 PM
WA man gets sailboat trapped beneath bridge - The Seattle Times NewsReader News Feeds 0 10-06-2011 11:10 AM
How to remove water beneath floor? (Catalina 22) DBlair8809 Gear & Maintenance 9 06-02-2009 02:24 PM
HTML code is Off
