Fold-Up Salon Table PSC34 - SailNet Community
post #1 of 5 Old 03-07-2017 Thread Starter
Hi all,
I have a PSC34 that is missing half of its salon table. It is the type that folds down from the bulkhead with a leaf pivoting out from underneath on a piano hinge, with some additional legs that pivot down to the cabin sole.
The cost to have Pacific Seacraft build it for me is prohibitive, not to mention the hassle of getting it safely to Mexico, so I am going to do it myself.
See attached photos. You can see the screw holes on the edge of the underside where the piano hinge use to be attached. The screw holes (17 of them) are exactly two inches apart, as are the holes in the hinge that attach the existing leaf to the cabinet on the bulkhead. I would assume then I need the same type of hinge, only longer.
I was wondering if some kind soul would help me out by taking some detailed pictures of their table and send them to me. I am particularly interested in the placement of the legs in the missing half of the table and how they locate in relation to the other half when the table is stowed.
Thanks,
Jeff_P is offline
post #2 of 5 Old 03-09-2017
Hush34's Avatar
Re: Fold-Up Salon Table PSC34
Hope these help.
Indecision may or may not be my problem.
Hush34 is offline
post #3 of 5 Old 03-09-2017
Hush34's Avatar
I would have had those to you yesterday but the internet connection here is brutal. I understand why the previous owners would have removed the drop down leaf, but do not understand whey they didn't keep it. It looks like the most critical part of the job is to line up the two legs correctly. I would attach your replacement leaf to the hinge then get the legs lined up with the down post holes in the floor. Good luck to you.
Hush34 is offline
post #4 of 5 Old 03-09-2017 Thread Starter
Hush,
Thanks for the pictures, they really help. Also your suggestion with regards to getting the legs lined up. Interestingly, I do not have any down post holes in the floor for the fold down table, but there appears to be locater holes for the other type of table that was available for the PSC34. See attached picture. Maybe the original owner changed his/her mind during the build? Should be fine I think without the locator holes. Thanks again.
Jeff_P is offline
post #5 of 5 Old 04-02-2017
Originally Posted by Jeff_P View Post
Hush,
Those marks look like they've been there for awhile. More than likely it's similar to what the PO did with my PSC34, they sold the original deck mounted table and purchased a wall mounted table from PSC.
Strange thing in my case, the wall mount table is a little different. I don't have the hinged legs (they are loose and mounted with pins into the bottom of the table, and there is no securement at the deck). Nor do I have the fiddles. I wish that I had both. In fact, I will probably add removable fiddles sometime in the near future. I'm also thinking that I should add some pins to the bottom of the legs as well, so that they can't accidentally slide out from under the table.
elliowb is offline
Beneteau First 29 - Salon Table trailsontrek Beneteau 3 07-16-2013 01:50 PM
Salvaged fold down cabin table? williamkiester Gear & Maintenance 2 05-14-2011 08:39 AM
Salon Table Extension nika44 Gear & Maintenance 0 04-13-2010 10:58 AM
Making a New Salon Table Cruisingdad Gear & Maintenance 17 03-26-2008 12:12 PM
Salon table kotsakis Gear & Maintenance 2 10-28-2006 10:47 AM
HTML code is Off
