psc 34 jackline configuration - Page 3 - SailNet Community
 12Likes
post #21 of 33 Old 07-08-2017
Re: psc 34 jackline configuration
Mr. Murdoch,
Sorry - dumb question: what is "the forward bail on our genoa turning (or foot) block"?
kbbarton is offline
post #22 of 33 Old 07-08-2017
pdqaltair's Avatar
Originally Posted by elliowb View Post
That is a great idea Bill. I haven't used my jacklines yet, but after reading this thread I decided to get them out and see how things would work. Well, I'm not sure if the PO ever used them before either because it sure doesn't seem like they will work. I hooked one end to the pad eye a the forward end of the cockpit and stretched it out along the side of the cabin trunk. I'm left with at least 10 feet extra when I get up to the bow. Since it's flat nylon, it doesn't cleat-off well, even with three full figure eights it easily slipped.
Did you install the cleats on the bulwarks yourself? I've been in the anchor locker recently to reinstall the windlass, and it doesn't seem like it would be very easy to reach up to the spot where your cleats are secured. If you did install them yourself, did you also add a backing plate? Aluminum possibly? If so, I suspect that it isn't glassed in, but still should help spread the load. Any help would be appreciated.
IMG_5491 by Bill, on Flickr
IMG_5493 by Bill, on Flickr
IMG_5494 by Bill, on Flickr
-- Bill Elliott
PSC 34
Belle Voile
Just so you know, that stitching pattern in nylon webbing is probably less than 50% strength. I've done a lot of testing of sewn nylon, and anything other than a very compact bar tack is weak because of differential stretch. A knot is stronger, but still far less than World Sailing standards.
elliowb and toddoh72 like this.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #23 of 33 Old 07-08-2017
Location: The house is in Kingsport, TN. Boats are on Watauga Lake and in New Bern, NC
Originally Posted by kbbarton View Post
Mr. Murdoch,
It's not a dumb question at all. It is just words that I dreamed up on my own because I did not know what the real words were.
What I am calling a "forward bail" is the bit of curved round metal ahead of the sheave of the block. It is the forward continuance (lower left in the photo) of the metal that supports the upper end of the sheave axle. I thought it looked like the bail of a pail.
wsmurdoch is online now
The Following User Says Thank You to wsmurdoch For This Useful Post:
kbbarton (07-09-2017)
post #24 of 33 Old 07-08-2017
Thanks for pointing that out. Once I've figure out exactly the length that I need for the jackline, I was planning on taking the line to the local sailmaker and have him re-stitch. However, I hadn't realized that the type of stitch is important too. Makes sense though. When I examine the stitch more closely, it really does look amateurish and poor workmanship. That's not something I like to see on anything that I trust my life to.
I also was wondering about the strength of the carabiner. I can't find any stamp on it indicating working load, so I'm suspect that it may be insufficient.
toddoh72 likes this.
elliowb is online now
post #25 of 33 Old 07-16-2017 Thread Starter
Just wanted to say Thank You again for posts. I ultimately purchased Wichard's Lyf'Safe Jackline system because it was the most convenient (but definitely not cheap!). For the aft attachment point, I'm installing a Wichard folding padeye (with backing plate) on the outer cockpit combing. This area is easily accessible for installing the backing plate from the aft quarter berth below and will ensure that the lines lay as flat as possible on the deck. I'm using the forward bow cleat for the forward attachment point. Besides this post, the most helpful information I found was the in the Practical Sailor E-Book called "MOB Prevention & Recovery." I highly recommend this read! I found the Wichard Lyf'Safe Jacklines on sale at Defender, but it's not currently available. Here's a link to where you can purchase them now: Wichard LyfíSafe Jackstays.
toddoh72 is offline
post #26 of 33 Old 11-27-2017
Had the same thing happen to me. Started using clean line tucked in. I would also say on a calm day at anchor put on your harness clip onto the jack line and climb over the side. You wonít sleep for a while.
My other 2 cents auto inflatable pfd with harness , NIGHTMARE. I donít like the autos anyway . Once again jump over and youíll find you canít swim at all once they inflate. Now imagine dragging down the side with a balloon around you .
One hand for yourself and one hand for the boat is no joke. I usually go crawling or butt sliding if itís really bad, but Iím old now and try not to get in the sporty stuff too often.
Safe sailing
elliowb likes this.
Capnbh is offline
post #27 of 33 Old 11-28-2017
pdqaltair's Avatar
World Sailing jackline strength requirements are based on breaking strength, not working load limit. Very likely, the locking carabiner is strong enough. Unsurprisingly, jackline, tether, and climbing gear standards are closely related (although there are important differences). Do be certain to grease the carabiner several times each season or it will seize.
elliowb likes this.
post #28 of 33 Old 11-28-2017
Thanks for the information. I just did a google search on World Sailing jackline strength and came across an article that appears to be a very thorough treatment on the subject.
https://www.morganscloud.com/2016/11...tion/#comments
-- Bill
Belle Voile
PSC 34
post #29 of 33 Old 11-28-2017
iMHO using anything other than a jack line and bowline your asking for trouble. Stitching wears and breaks carabiners fail and rust. If you trust the webbing and your knot tying skills , why would you add something that could break? Probably doesnít look as cool and tidy but will keep your butt on the boat! I know the harness has that as well but it doesnít sit out in the sun , hopefully.
Hereís what strange In That article, his idea of separate jacklines at the mast when he has mast pulpits right there? I would hope they were strong enough to clip onto. Also Iím sure your using double line on your harness? It makes life a lot easier.
Safe sailing and hope none of us ever have to test these theories.
elliowb likes this.
Capnbh is offline
post #30 of 33 Old 11-28-2017
My beam is only 10' 0" so I don't think that a centerline jackline is feasible. I'm going to stick with a jackline on each side. However, as to knots rather than stitching, I know that knots in typical running rigging line can easily reduce strength by 50% or more. I'm not sure that stitching has that same effect on strength. My initial guess would be that it doesn't, for the simple reason that a stitched loop is more like a splice, and a well done splice can maintain 90% of the lines strength. Then again, maybe I'm over thinking this whole thing.
-- Bill
Belle Voile
PSC 34
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
Jackline attachments Barquito Gear & Maintenance 13 06-20-2013 07:01 PM
Jackline system Joel H. General Discussion (sailing related) 22 05-01-2013 10:50 PM
Name this light configuration sailboy21 Seamanship & Navigation 8 11-11-2010 05:29 PM
Jackline Breaking Strength sailak Gear & Maintenance 5 05-28-2009 12:14 AM
used PSC-34's x 2 in san diego, x 1 PSC-31 in dana point AlexHazzard Pacific Seacraft 0 08-18-2007 02:44 PM
HTML code is Off
