greasing rudder gudgeons - SailNet Community
post #1 of 3 Old 04-30-2018 Thread Starter
jvlassak's Avatar
Hi all - as I am getting the boat ready for the season, I noticed a slight squeak as I turn the rudder to starboard - it only happens toward the end of the range. I typically go through the entire pedestal greasing/oiling the various parts, so I think the sound is coming from the rudder and it's probably time to grease the gudgeons. Any recommendation on how to best do that? The lower gudgeon has a ring between the skeg and the rudder, so it's not obvious to me how one could get any grease in there. Thanks - Joost
1995 Pacific Seacraft 34
Iphigenia
jvlassak is online now
post #2 of 3 Old 04-30-2018
DaveMancini's Avatar
Re: greasing rudder gudgeons
The gudgeon should have a hole in the bottom. Put some waterproof grease in a large syringe (~60ml or so) with a short piece of tubing on the end (if necessary) and force the grease up into that hole and into the rudder shaft interior so that the grease falls back on to the gudgeon inner surface (hopefully no former owner has mistakenly sealed up the bottom of the rudder shaft). Also, hopefully the ambient temp is high enough so the grease is not too viscous so the grease can work its way into the joint between the rudder shaft and the gudgeon. Work the rudder back and forth to get the grease spread along the mating surfaces inside.
Dave
DaveMancini is online now
post #3 of 3 Old 04-30-2018 Thread Starter
jvlassak's Avatar
Dave
Thanks, Dave, that's exactly what I needed to know.
Cheers,
Joost
Iphigenia
bolt on Gudgeons? lokikenobii Gear & Maintenance 6 02-22-2016 02:34 AM
bedding rudder gudgeons dixiedawg Gear & Maintenance 5 11-15-2013 02:10 PM
Bedding compound for gudgeons oomfh Gear & Maintenance 0 08-06-2010 07:08 AM
Replacement Gudgeons donhaller Gear & Maintenance 5 01-21-2009 10:24 PM
Greasing Outboard bobendaxi Gear & Maintenance 2 04-06-2005 10:35 AM
HTML code is Off
