Selden 204s Furlex - SailNet Community
post #1 of 6 Old 05-31-2018 Thread Starter
deisher6
Selden 204s Furlex
We are considering a Selden 204s Furlex for the jib on our PS34. It appears to be a reasonably priced rugged system.
Are there any Pro or Con experiences with this product???
Thank you in advance for any comments.
regards charlie
post #2 of 6 Old 06-07-2018 Thread Starter
deisher6
Re: Selden 204s Furlex
Well OK then! Ordered one, will post how it works out.
regards charlie
post #3 of 6 Old 12-04-2018 Thread Starter
deisher6
Have a couple of weeks experience with the Seldon furler.
Cost about $2600. Includes a moderately high cut 250 sqft jib that sheets well to the middle set of tracks. Also included a new forestay and installation. I could have probably installed it but nearing 70 I probably will not be installing any more furlers. So it was worth the price of a rigger to me.
It works well. Easily furled the jib in 25 knot gusts. Reefing line could be larger for ease of handling, but I don't think that the furling drum can handle a larger diameter of line. Looking into splicing a larger line on the part that extends from the drum to the cockpit. Seems to be robust enough. No complaints.
I did not expect roller furling to be very effective in reefing. So far it seems to raise the enter of effort of the sail not reducing the heeling effect of the depowered jib. From experience so far, I think that just furling the main, then taking in the jib are the first two choices in reducing sail. A furled main and staysail is all that I have to reduce sail so far!
Did make a bonehead mistake in securing the spinnaker halyard on the bow pulpit. The halyard got caught in the jib at the peak when furling. Fortunately found the problem prior to running the reefing line to the main winch.
Smooth Sailing
regards charlie
post #4 of 6 Old 12-04-2018
ASA and PSIA Instructor
Smooth Sailing
regards charlie
You should never need to put a jib furler line on a winch - if you want to, better to investigate the situation to find the actual problem. Using a winch, you are likely to break some gear.
Sent from my SM-G965U using Tapatalk
sailingfool is online now
post #5 of 6 Old 12-04-2018 Thread Starter
deisher6
Hey Sailin'fool:
The main winch, a Lewmar 40 something, was I assure you, just a passing thought as the sail was flogging, sheets were knotting, stopper knots pulled through turning blocks, and there was no one to yell at.
Checked it out found the problem and lived to sail another day. Did take a couple of shots from lines knots though. Good reason to use knots instead of shackles.
regards charlie
post #6 of 6 Old 12-06-2018
DaveMancini's Avatar
I like your style, Charlie.
DaveMancini is online now
Selden vs Lewmar Goldfinger Gear & Maintenance 7 07-17-2012 07:14 PM
Selden Furlex 100S trantor12020 Gear & Maintenance 7 05-05-2012 06:20 AM
Selden Bowsprit CGMojo Gear & Maintenance 4 02-22-2008 10:46 AM
Selden Furlex question studwellboiman31 Gear & Maintenance 2 01-04-2008 05:29 PM
Selden Furlex 100S trantor12020 Gear & Maintenance 0 07-04-2006 12:08 AM
HTML code is Off
