Original Head on PSC 34 - Page 4 - SailNet Community
 7Likes
post #31 of 46 Old 03-10-2020
jvlassak's Avatar
Re: Original Head on PSC 34
Bill, thanks - this is very helpful. The smell isn't too bad yet, but seems worse than in previous years. Not a job I'm looking forward to...
Joost
1995 Pacific Seacraft 34
Iphigenia
jvlassak is online now
post #32 of 46 Old 03-10-2020
chef2sail's Avatar
Originally Posted by jvlassak View Post
Bill, most likely I'll be replacing the sanitation hoses in my boat this spring. I noticed some of the old hoses are cracked and the small is noticeably stronger than before.
How is the sani-flex working for you? Are you still happy with it? A few more questions if you don't mind. What is the inner diameter of the hose you used? Is it 1.25 or 1.5 inch? How much hose did you need? And how much time should I budget for this? I think you used a dremel tool to remove the hoses from their fixture - how did you prevent scoring the fixtures?
Thanks!
Joost
I prefer the trident green stripe hose. 12 years since the replace and still no smell. The trick is fresh water rinse, leave no effluent in the line, and we have 2 vents for the tank.
https://www.downwindmarine.com/Marin...-90891025.html
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #33 of 46 Old 03-11-2020 Thread Starter
Joost
In my case, the job was not as bad as I had built it up to be in my head (no pun intended).
jvlassak likes this.
-- Bill
"Belle Voile"
PSC 34
elliowb is offline
post #34 of 46 Old 03-11-2020 Thread Starter
Looks like nice hose too. How is it to work with?
I agree, fresh water rinse and lines that don't have any low spots are essential. Despite that, there are always spots, for instance the hose that goes up to the deck plate, where there will be effluent sitting in the hose. Then it simply comes down to how long before it penetrates the hose wall.
-- Bill
"Belle Voile"
PSC 34
elliowb is offline
post #35 of 46 Old 03-25-2020
Which composting head did you go with and are you satisfied? No odors?
tquig is offline
post #36 of 46 Old 03-25-2020
Barquito
Barquito's Avatar
Barquito is online now
post #37 of 46 Old 03-25-2020
deisher6
TQUIG: We installed an Air Head because of its slightly smaller size. It fills up the head compartment but works OK as far as size. It does not smell. After some usage we quit adding toilet paper and it seems to work better. Was did smell for about 1.5 years was left over smells from the previous head. Smells lingered even after removing all hoses, cleaning and sealing the inside of the holding tank.
regards charlie
PSC-34
Windrunner
post #38 of 46 Old 04-08-2020 Thread Starter
Thanks!
Joost
Finally got some measurements for you on lengths. I'd say that 25 feet would take care of you, if you don't include the direct overboard discharge (I got rid of that line, following Bill Murdoch's suggestion). Seven feet from the head to the vented loop, 5 feet from the vented loop to the tank, another 5 feet from the bottom of the tank to the cleanup, and then 3 feet on the tank side of the pump and 4 feet from the pump to the discharge thru hull. All of those are rather generous measurements so you'll have a little left over more than likely.
-- Bill
"Belle Voile"
PSC 34
elliowb is offline
post #39 of 46 Old 04-08-2020
jvlassak's Avatar
Hi Bill,
Thanks so much for the measurements - 25 feet is exactly how much hose I got. I'm actually in the middle of the project right now. I decided to keep the direct discharge line, mainly as a backup system, but am installing a Y-valve instead of that T-fitting. That way the direct discharge is always closed off except when we need to use it for some reason. Removing the old hoses was a pain...
Thanks,
Joost
elliowb likes this.
Iphigenia
post #40 of 46 Old 04-08-2020 Thread Starter
Hi Bill,
Thanks,
Joost
I think that you'll be glad that you made the change. It's so much nicer to open up the boat and not smell or have to apologize to a guest for the 'boat smell.' Make sure that you use some sort of bleach or disinfectant (I used Odoban) and wipe down all the interior spaces under the sink and the vee-bunk. Mine were pretty saturated with odor.
One other think you might consider, while you're at it. I didn't have any way of knowing whether the holding tank was full. I installed a clear, 4" inspection port in the lid of the tank. Seal it VERY well though.
-- Bill
"Belle Voile"
PSC 34
elliowb is offline
Head in PSC 34 jvlassak Pacific Seacraft 12 08-19-2017 11:21 AM
Original manufacturer of opening portlights on '78 Cal 34? Carpevelum Gear & Maintenance 1 03-01-2011 04:00 PM
PSC 34 vs Pearson 34 - a good problem to have fefrich Pacific Seacraft 1 02-15-2010 10:15 AM
LAVAC Head in PSC 34/37 BirdBrain333 Pacific Seacraft 4 12-29-2008 09:56 PM
used PSC-34's x 2 in san diego, x 1 PSC-31 in dana point AlexHazzard Pacific Seacraft 0 08-18-2007 01:44 PM
HTML code is Off
