Motoring RPM - Page 3 - SailNet Community
 8Likes
post #21 of 23 Old 08-08-2019
Re: Motoring RPM
Im jealous of anyone who can have the controls/conditions needed to do fuel burn rate tests.
Weight will also be a factor in your prop tests
RegisteredUser is online now
post #22 of 23 Old 08-08-2019
colemj's Avatar
Re: Motoring RPM
Do you reach max rpm in neutral, like someone asked earlier? This is your most important test right now. If so, then it isn't a throttle problem. It takes surprisingly little growth on the bottom or prop to drastically limit rpm. A couple of barnacles on the blades will do it. If it doesn't reach it in neutral, then make sure the tach is correct, then start looking at the throttle linkage, fuel, etc.
Many engines come with a choice of transmission gear ratios, and I think that one did too. The correct size of the prop will have much to do with which gear ratio you have. This probably explains why you find people with different sized props on the same engine.
To summarize, troubleshooting this problem follows these steps:
1. see if you reach full rpm in neutral. If so, then #2, if not then #3
2. clean the bottom and prop very well
3. check that the tach is correct. If not, correct it. If so, #4
4. all the other possibilities like throttle linkages, fuel delivery, transmission, fuel system internals, etc
Mark
olson34 and PhilCarlson like this.
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #23 of 23 Old 10-31-2019
Re: Motoring RPM
I adjust engine power by the quarter wave, because as a displacement boat approaches hull speed the quarter wave grows rapidly. The energy dissipated in the quarter wave is why it takes a lot of power to exceed hull speed. This method also works well when motorsailing.
SanderO likes this.
rschudy is offline
HTML code is Off
